Went in for 130/90-16, Came out with MT90-16
I decided to replace the stock Dunlop's with Metzler ME880's. I called a local shop and asked if they had the following sizes:
Front = 130/90-16
Rear = 180/65-16
They said yes to both. Great!
When I got the wheels back, I noticed that the front was not a 130/60-16, but was actually MT90-16. They guy said it's the exact same size, but said it's a metric size instead of a standard size. It looked the same size, so I said no problem.
But when I got home and looked on Metzler's website, I notice that the specs are different between the tires.
130/90-16 TL 67H F
MEASURING RIM 3.00
RIMS PERMITTED 2.50-3.50
MAXIMUM WIDTH 142
MAXIMUM DIAMETER 657
LOAD CAPACITY 677
MIN/MAX PSI 38-42
MAX SPEED 130
TREAD DEPTH 6.0
TIRE WEIGHT LBS 14.55
MT90B-16 TL 72H F
MEASURING RIM 3.00
MAXIMUM WIDTH 136
MAXIMUM DIAMETER 643
LOAD CAPACITY 783
MIN/MAX PSI 36-40
MAX SPEED 130
TREAD DEPTH 5.0
TIRE WEIGHT LBS 15.95
So my question is, which one is "better". It looks like the MT90 has a higher weight rating, but has a lower max PSI and is heavier and has less tread.
So price being equal, which one should I have gotten?
Front = 130/90-16
Rear = 180/65-16
130/90-16 TL 67H F
MEASURING RIM 3.00
MAXIMUM WIDTH 142
LOAD CAPACITY 677
MIN/MAX PSI 38-42
MAX SPEED 130
TREAD DEPTH 6.0
MT90B-16 TL 72H F
MEASURING RIM 3.00
MAXIMUM WIDTH 136
LOAD CAPACITY 783
MIN/MAX PSI 36-40
MAX SPEED 130
TREAD DEPTH 5.0
Hmmm.... I wonder now too. I have the same tire on my front but never thought a thing about it. I just used the "tire finder" on the website I bought them from and punched in my bike. It came up with the MT90-16 so I got it. Curious what, if any, difference there is other than the spec numbers.
The MT is fine. A deeper tread on the Metz mens squat because the compound is softer, and it'll wear faster. Plus it's only 1/32" difference.
From experience, I've never been able to put as many miles on a Metzeler (and Avon) than on a Dunlop.
With less tread depth I wonder if the MT is a harder compound? I too am curious as to what makes the difference. I'm sure it fits and works but will it last as long, different handling characteristics, or ?? Heck maybe it is better!
Since returning to Metz is on my list later this year I will have to look into this myself. Post up if you get some more detail. Thx
only thing is, both of the tires he listed, are metzlers..... so, one metz, has deeper tread than another metz, and one is rated at a higher weight load. never heard of that before. so, curious to see his outcome.
corb
i agree with you on the second bit in bold. i have had 2 bad experiences with dunlop, and have been a metzler fan for years. i personally feel more sure footer on ME880s. but, to each his own. some have had bad times with metzlers, etc..... like i said, to each his own.
corb
corb
Front = 130/90-16
Rear = 180/65-16
130/90-16 TL 67H F
MEASURING RIM 3.00
MAXIMUM WIDTH 142
LOAD CAPACITY 677
MIN/MAX PSI 38-42
MAX SPEED 130
TREAD DEPTH 6.0
MT90B-16 TL 72H F
MEASURING RIM 3.00
MAXIMUM WIDTH 136
LOAD CAPACITY 783
MIN/MAX PSI 36-40
MAX SPEED 130
TREAD DEPTH 5.0
Front = 130/90-16
Rear = 180/65-16
130/90-16 TL 67H F
MEASURING RIM 3.00
MAXIMUM WIDTH 142
LOAD CAPACITY 677
MIN/MAX PSI 38-42
MAX SPEED 130
TREAD DEPTH 6.0
MT90B-16 TL 72H F
MEASURING RIM 3.00
MAXIMUM WIDTH 136
LOAD CAPACITY 783
MIN/MAX PSI 36-40
MAX SPEED 130
TREAD DEPTH 5.0
