J&M 500w Audio StreetGlide ROKKER
#41
Our Streetglide ROKKER shows real good at the shows, without the tail trunk in the way that is on the Ultras ,,,,
a cool 6 speaker system on an Ultra, using our new 500w J&M will be even more impressive ,,,
and it is hard to think of ANYTHING more impressive than J&M's ROKKER ,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
#42
If the weather was nice, I'd ride mine up and show ya !! .....
Good luck at the show ! Hope it works ou well for you. See ya this weekend....................
No better time for this venue in NE Ohio , than in late January ... marketing geniuses !!
Attendance should be through the roof !
#43
thanks john. I will do both when time comes.
r8rs4lf ,,,,,
don't have the exact dimensions, but the new J&M 500w amp is a few inches longer than our 250w amp ,,,,, and just BARELY fits inside the Harley Batwing fairing ,,,,,
the new amp kit will come with a mounting bracket for you to use, so that you won't have to try and glue it down with Velcro ,,,,
ranman469 ,,,,
I cannot think of any way to cram the J&M 7.25" speakers into the rear speaker pods on the Ultra ,,, but the J&M 5.25" upgrades for that position, do an outstanding job ,,,,,
ranman469 ,,,,
#46
New 6.5 HD Speaker box
John
My winter project has been delayed once again. I made it to IMS in Washington DC and will not make the IMS in NY. The youtube Rokker is impressive. In the Rokker Vid you retro fitted a Harley Speaker Box. If so will your kit for the 7.25 kit lower allow the use of the 6.5 speaker box from HD? If not will I have to buy new speaker box from JM to accommodate this setup? Thanks for always keeping in touch with MotorZ enthusiast.
#47
GlacierPearl ,,,,,
that is a very good question ,,,,,, and one I need to think about for a few days ,,,,,,
we just need to build a replacement rear speaker pod for all 2006-2011 Ultras, that will hold all of the factory Harley passenger controls AND the J&M 7.25" speakers !??!,,,,,
sounds simple enough huh ? ,,,,, now I have even more work to do ! ,,,, will it never end ? LOL ,,,,,,
HCFXDC17 ,,,,,
the new J&M LOWERS speaker housing/kits will utilize the stock Harley LOWER fairing shells ,,,, you will simply unbolt the innards of the Harley units and bolt in the J&M inner shells with 7.25” speaker/grill/tweeters/mids etc ,,,,,,
HCFXDC17 ,,,,,
#49
Passengers are meant to sit back & enjoy the ride !!
#50
GP, perhaps you can edit your signature to mention that you have two automotive amps mounted in the tour pak and 6X9 (?) speakers in the saddlebags. I suggest that because it may make it easier for folks to decide whether what you have is worth investigating or not. For example, in my case, if I was interested in not using the tour pak or saddelbags for mounting audio equipment, I wouldn't bother to look further by clicking on your link if I saw in your signature that I: (1) needed a tour pak and would be giving up significant space in it for the amps; and, (2) would be mounting speakers in the saddlebags.
Just my suggestion.
Carl
Just my suggestion.
Carl
