$15 tourpack relocator
A buddy of mine wanted to move his tourpak back 2 inches....the relocator kits are expensive so we decided to make our own....
The whole project cost about 15.00....
We used:
1/4 x 1 1/2 flat bar stock....12.00 ace hardware
4 additional bolts, nuts, and grommets
Measured out the distance we needed for the barstock...about 13 inches
Drilled a set of holes that matched the tourpack support...drilled another set back 1" and 2" (we used the 2")
Bolted the barstock to the support, slid the tourpack back 2" and dropped the new bolts in....We used rubber grommets between the tourpak and the new bracket for added vibration dampening.....
Wa La....
Simple, cheap, functional.....the 1/4 barstock does not flex....we are going to tear it apart later on and countersink the holes in the barstock as an upgrade....
We used:
Wa La....
Bulldog13
2014-2023 Touring Models
07-07-2014 07:59 PM
BillMichaels
03-28-2007 02:07 AM
