ABS light
Old 01-16-2011 | 01:59 PM
1flhtk4me's Avatar
1flhtk4me
Has the dealer even consulted MOCO?
Old 01-17-2011 | 07:54 AM
lonslo's Avatar
lonslo
I had intermitent problem that I found to be a broken abs wire that was at the steering head of the bike where it flexed during turns. Most of the time the abs seemed fine but if i started making tight turns then the lite would come on.
Old 01-17-2011 | 08:36 AM
glenalt's Avatar
glenalt
You've gotten some good advise. You need to escalate the complaint and it needs to be fixed. It's a safety issue and they should be very concerned.
Old 01-17-2011 | 09:02 AM
batman4706's Avatar
batman4706
Default Lemon Law
Most places after they've tried 3 times on same problem it falls under the lemon law.
Old 01-17-2011 | 09:29 AM
lonslo's Avatar
lonslo
Dont know about other states but in Ga. they get one attempt if it is involving brakes or steering. Lemon law got me a new pickup a while back. Be sure to keep a good record of what has been done. Good luck.
Old 01-17-2011 | 09:39 AM
1Harleyrdr's Avatar
1Harleyrdr
MINE did this after running through a puddle of tranny fluid. i pressure washed and it went away.
Old 01-17-2011 | 11:35 AM
Nute's Avatar
Nute
The light indicates a fault if it is on. Doesn't matter what the cause is there's something wrong. If your light is on the ABS no longer is working. I would take it back to the dealer and get it fixed. The cause should be identified and corrected. You paid a lot to have a ABS and as such you should be able to rely on it to do what it supposed to do.
Old 01-17-2011 | 11:56 AM
laduckslayer's Avatar
laduckslayer
Mine developed a pinch at the sensor. Easy fix, but it took many hours of working through the 70 or 80 codes ....
rossWG
08-03-2021 09:56 PM
woodmaniac
08-05-2012 10:44 AM
okieblue62
08-01-2010 03:10 AM
batman10
05-18-2010 08:33 AM
DocDyna
12-02-2009 07:59 AM
Quick Reply: ABS light
