V&H Dresser Duals?
Old 01-21-2011 | 06:14 PM
hover's Avatar
hover
Originally Posted by Rhonda
Are the head pipes separate or welded together at the support? I'm asking because of ease of installing. The factory header is a pain. If they are separate are there supports on both pipes? Thanks! Allyn
They are separate pipes, come with mounting brackets so they can't sag. You need 2 new HD muffler clamps if you buy these. You can purchase 2 new HD exhaust gaskets also if you don't want to use the V&H. These are pretty easy to install if you have someone to hold the front pipe while you start the nuts on the heads. I'm talking 2009.
  #32
Old 01-22-2011 | 05:44 PM
Jkey's Avatar
Jkey
I have a 2010 FLHTK. I had the stock exhaust on for a very short time. The heat was murder even in September. Bought an xied-10 from Nightrider and a K&N replacement filter. Helped the heat as the xied made the fuel mixture a bit richer. Not being satisfied I purchased the Dresser Duals from Fuel Moto along with the Power Commander V and Stage 1 A/C. I am running Rush slip ons with a 1.75" baffle. Love the stereo sound. They bark when you get into it and can still hear the radio when cruising. Heat issues are gone. The xied helped with heat but still had some. Jamie sent me two maps to run on the P/C. One with some power and one for the highway when I want fuel economy. Haven't had a chance to try the eco map yet.
  #33
Old 01-26-2011 | 07:33 PM
97badfatboy's Avatar
97badfatboy
V&H duals are absolute power robbing junk. Just my humble experience with them don't ya know!
  #34
Old 01-26-2011 | 09:17 PM
EastSideBikerTrash's Avatar
EastSideBikerTrash
I have to agree with this on the 09 and up bikes where the front cylinder's pipe goes under the frame. Two 90 degree bends. On previous years this was not an issue.
Plus I dont like the way they look on the right side with the pipes stacked on each other. Too much clutter. They do sound awesome though.
dave
  #35
Old 05-30-2011 | 08:29 AM
hdman6's Avatar
hdman6
Question
ok, I have a 2008 Ultra classic anniversay that I bought last fall with stock header pipes, reinhart 3.5 slip-ons, and a stage 1 kit on it. It also had a Screamin eagle pro race tuner in the tourpak. So i am a little lost here sine I traded in a 1993 with none of this computer stuff on it. I thok the most advance thing on my 1993 was the self canceling turn signal (lol). So I will be in sturgis this yr (3rd time out) and want to get the V & H dresser duals installed at the balck hills harley dealer where they have all the vendors set up etc. I have been reading that this will reduce the major heat problem by my leg and my wife foot. ( on fire almost). So since this bike had a tune already set up witht he stage 1 done etc will it need retuneing with the dresser dual install? And im not sure how the tuner works, I have no cables or cd or anything just the orange box that is the tuner. Do you think the V & Hines tent would tune it too if it needs it and how do you know if it is needed? Like I said i had a carb bike and that was a piece of cake before all this.. But this is real...... nice. thanks for your advice out there Jeff
  #36
Old 05-30-2011 | 08:38 AM
hdman6's Avatar
hdman6
forgot one more question... Do i have a cat? I do believe I have a 02 sensor from what I have read and does the dresser duals still work with that? thanks Jeff
  #37
Old 05-30-2011 | 09:35 AM
mgmmgm's Avatar
mgmmgm
I like my V&H power duals and Monster Rounds.
  #38
Old 05-30-2011 | 09:37 AM
mgmmgm's Avatar
mgmmgm
here is my short video of the pipes I have on my RKC
http://www.youtube.com/watch?v=vJAx-zqtVoU
  #39
Old 05-30-2011 | 10:01 AM
harleycat225's Avatar
harleycat225
I had a 08 Anniversary Ultra too. I had a stage 1 done with a dyno tune with the stock head pipe. I later installed the Vance and Hines Dresser Duals and never had it retuned. The bike ran great with the tune it had. Just my 2 cents. Oh yeah your bike does not have a converter.
  #40
Old 05-30-2011 | 11:08 AM
ultra5516's Avatar
ultra5516
I'm looking to do the vance & hines 2-1 on my Ultra, I have true dauls rineharts now and the heat on my left leg is just unbelievable burned my rain gear and heated suit on it. Its time for it to go!!!!!!! Any one running the vance & hines 2-1?? Looking for help
Quick Reply: V&H Dresser Duals?
