Bagger Brace install: apparently my dog bone is bent upward
Old 01-15-2011 | 04:51 PM
albngore's Avatar
albngore
Default Bagger Brace install: apparently my dog bone is bent upward
2006 Ultra
I received my Bagger Brace today and believe that my dogbone is bent upward. I am afraid to try to lever it downward by putting pressure with a bar on the oil pan without some help from others who have encountered the same situation. I cannot think of any other way to lever it downward than with a curved bar that will exert pressure on the oil pan.
The instructions say to make sure the dogbone is level with the frame rails and it is in fact about 3/8" or more bent upward, according to my straight edge. There are no obvious marks on the dogbone to indicate that it hit anything, but the brace will not slip in behind it for the installation.
Sure would appreciate any assistance on this. Otherwise I guess I will just have to send the brace back since I cannot use it if I cannot get the dogbone crossmember to move down.
Thanks.
Old 01-15-2011 | 05:03 PM
FX4's Avatar
FX4
Mine was bent a little, I don't know about 3/8ths though, maybe more like an eighth of an inch. I would call Bitchen Baggers Monday and talk to them about it. I'm sure they a have a fix.
Old 01-15-2011 | 05:46 PM
1flhtk4me's Avatar
1flhtk4me
I recall someone or one of the brace mfg's selling a tool to straighten the support.If you do a search on braces here, you may find some info.
Dont see why it could not be straightened with some steel plates and bolts.
Old 01-15-2011 | 06:02 PM
SaltySARdog's Avatar
SaltySARdog
True-Track (a sponsor) carrys the tool. 20-00ET X-Member Tool, Cost $40.00, maybe they will give you a member discount. Hope this helps,
Old 01-15-2011 | 09:32 PM
user 8373900's Avatar
user 8373900
Instead of prying on the oil pan pulling down, can you put something (like a bolt)through the cross-member and protect the frame with something like a piece of hose and pull upwards on the bar using the protected frame as a fulcrum point? Did I explain that clearly?
Mark
Old 01-16-2011 | 05:56 AM
albngore's Avatar
albngore
Thanks all. I pried it down satisfactorily little by little and did the install. Maybe the dogbone is not perfectly straight but all the parts fit Ok. I bet a former owner put a jack right on the crossmember and bent it up.
The crossmember actually bent down quite easily with a curved pry bar against the oil pan. Seems like a pretty stout pan.
Thank you.
Old 01-16-2011 | 06:53 AM
1flhtk4me's Avatar
1flhtk4me
Wow,your brave!
Old 01-16-2011 | 12:31 PM
2D3K1H1B1HIM's Avatar
2D3K1H1B1HIM
Had the same problem just worked on it till it bent enough to put brace on.Once brace is on tq to specks,blue locktite and adjust after a few miles ,it will go back straight.
Z
03-05-2016 07:12 PM
aobfarm
Engine Mechanical Topics
05-03-2015 10:16 PM
albngore
01-13-2011 01:43 PM
jasle
09-03-2010 12:02 PM
FFeric
05-04-2009 12:05 AM
Quick Reply: Bagger Brace install: apparently my dog bone is bent upward
