18" wheel/Brembo conversion problem
Old 01-14-2011 | 07:09 PM
jasilva's Avatar
jasilva
Default 18" wheel/Brembo conversion problem
Trying to put an 18" front wheel from a 2010 SG on my 2006 SG, got the 2010 axle, spacers(2 identical), nut and washer. Also using the Brembo brakes, these are from an 08 Road King. Got it put together and the brakes are binding. Without the calipers the wheel spins nicely, as soon as I install the calipers and tighten the mounting bolts it drags so bad I need 2 hands to turn the wheel. Anyone have any idea what may be the problem?
The only issue I had when assembling it was the spacers seemed tight going in, had to spread the forks slightly to get the second spacer in place, but that may have just been due to me struggling with it by myself.
Thanks,
Joe
Old 01-14-2011 | 09:13 PM
robertg's Avatar
robertg
What rotors are you using? You will have to use the 08 and newer ones.
Old 01-14-2011 | 10:01 PM
user 8373900's Avatar
user 8373900
I just bought a chrome front end for my 2011, and the parts book says 2009 and up are different. The axle size has changed. How did you get the new axle to fit? Are you sure it fits properly?
Mark
Old 01-14-2011 | 10:14 PM
Ron "Gunner" Retzlaff's Avatar
Default Check the calipers
If you are getting the wheel to rotate without the calipers being snugged down, check to make sure the calipers don't need to be shimmed so that they are centered over the rotors.
I don't have a manual for your bike and I am just trying to think through the issue. I could be completely off base with my suggestion. Best of luck!
Old 01-15-2011 | 03:40 AM
DTTJGlide's Avatar
DTTJGlide
Check to make sure you didn't get a wheel from an ABS bike, the left side bearing on an ABS bike is thicker than non ABS. You should not have had to spread the forks to get it in. The fork legs are the same from 00 to 11, the axle size is only different in the center of the axle where the bearings & spacers run, the part that goes through the legs is the same as the older 1" axle.
Old 01-15-2011 | 03:46 AM
DTTJGlide's Avatar
DTTJGlide
Mark
The only difference in the chrome front end kits is the different axle covers for the newer axle, the legs are the same.
Old 01-15-2011 | 08:57 AM
jasilva's Avatar
jasilva
This was it, dumbass that I am I didn't double check the bearings. Guy I bought it from said it came from a non-abs bike so I ran with it. Oh well, just a reminder to double and triple check EVERYTHING when wrenching.
Old 01-15-2011 | 09:36 AM
shore's Avatar
shore
I did a 18" on my 07 and my calipers where binding...the 18" wheel is offset a little. Small fender shim on the right caliper and took a little off the left caliper with a dremel and it works good. There is no OEM spacer that fits perfect.
I used a flush mount 08 and up axle and 07 and down spacers on a non-abs wheel.
Old 01-16-2011 | 11:04 PM
jasilva's Avatar
jasilva
Actually with the correct bearings, spacers, rotors and calipers it doesn't need any shims(all 08 and later parts). Once I changed out the abs bearing for the standard bearing on the left side it went right together and works great.
Old 01-17-2011 | 03:15 AM
1sweetglide08's Avatar
1sweetglide08
Should have been a direct bolt on when going ABS to ABS or non ABS to non ABS. I did it with no problems.
cmshdfx4
10-04-2015 05:13 PM
roadkingbigjoe
05-08-2014 02:55 PM
plumberoon
Wheels/Tires
07-21-2012 12:01 PM
06sweetglide
05-13-2011 07:14 PM
danman2540
03-24-2010 03:20 PM
Quick Reply: 18" wheel/Brembo conversion problem
