107 for Baggers
Old 01-14-2011, 06:54 AM
springer 03's Avatar
springer 03
springer 03 is offline
Revolution Performance had some serious issues in the past. Buyers beware!
Old 01-14-2011, 07:48 AM
harleytuner's Avatar
harleytuner
harleytuner is offline
You have to be a little more specific than that. What kind of issues? We're talking pistons (made by J.E.) and jugs (heavier than stock, not bored out stock ones) here.
Old 01-14-2011, 08:43 AM
springer 03
Pages and pages have been posted here and on other sites. No need to rehash, do some searching.
Old 01-14-2011, 08:57 AM
VETERAN75's Avatar
VETERAN75
VETERAN75 is offline
The fuel moto kit is cheaper because you have no head work. However he show's to be making the same tq numbers as those with headwork only the hp is shown to be lower than those with headwork. Most of the 107 kits are bored oem cylinders and haven't heard of any with heat distorting issues. Would not worry myself on that one. I have the Headquarters kit on mine and I am very happy with it.
It says complete kit but you will need to upgrade air cleaner and exhaust system to get the performance he is showing on his dyno sheet at the site. Note from their site:
Retail Price $1299.00 Complete kit
$1995.00 installed at our location including a professional Dyno tune
Notice here
Fuel Moto also offers package deals for the 107" kit bundled along with tuning components, exhaust systems, and air cleaners. We have several Dynojet PC-V maps available for our 107" kit
Also pulling that much tq you will need a stronger than stock clutch spring because it will slip. Trust me. Either a vpc92 or the SE clutch spring are my recomendations. You may have need of compression releases also with this kit to help starting with the high compression which means head work. I do not know that for sure. I am not downing fuelmoto just trying to make sure you have all of your bases covered because these kits are engine components only. You always need more to make it a complete overall bike kit ie: air cleaner, exhaust, tuner and map, clutch etc. It all brings in large amounts of cost to the table if you don't already have these upgrades. Hope this helps.
harleytuner
You brought it up, figured you'd hit the highlights. No worries. I'll search.
Old 01-14-2011, 09:01 AM
Big Twi$t's Avatar
Big Twi$t
Big Twi$t is offline
Looks like you need to follow your own advice and do some research. The issues you are referring to are no longer issues.
Old 01-14-2011, 09:23 AM
Pittsburghglide2010's Avatar
Pittsburghglide2010
Pittsburghglide2010 is offline
Currently I have bub 8s true Duels, K&N high flow and a thundermax zipper. So all I would need is the kit and a clutch spring I guess. Will that spring make the clutch strong enough or is more needed
Old 01-14-2011, 09:40 AM
lkr0's Avatar
lkr0
lkr0 is offline
I went with HQs 107 (twice) I luv it--don't think you can go wrong with T-Man, HQs, GMR, S&S 106, AMS 105
Old 01-14-2011, 09:59 AM
springer 03
Only fools repeat the same things and expect different results. Even if they have cleaned up their act, too many ghosts in the closet to take a chance.
Old 01-14-2011, 10:05 AM
lkr0's Avatar
lkr0
lkr0 is offline
it may or may not make the clutch strong enough -- my clutch with heavier spring was slipping went with AIM T-92 http://www.aim-tamachi.com/home.php?cat=18-- it won't slip with it on the bike.
Quick Reply: 107 for Baggers
