suspension issues
Old 01-13-2011 | 04:32 PM
towmasterd's Avatar
towmasterd
Stage III
Default suspension issues
we drive a 2006 electra glide classic. my problem is the bike seems to "hit " hard sometimes while driving . my rear shocks are set at 30 lbs and my rear tire is at 36 lbs....any suggestions ?
Old 01-13-2011 | 04:52 PM
grbrown's Avatar
grbrown
By 'we' do you mean you ride 2-up? If you do it is quite common to suffer that problem. First I suggest your tyres are low on pressure. I run a lot more air than that when we are 2-up, above what the handbook says, to help both ride and handling. I reckon the handbook pressures for 2-up are too soft!
As for your shocks, I am not sure about your year. I eventually gave up on Harley air shocks and fitted custom-built Ohlins. Don't ever hit hard or bottom out now! Worth every penny.
Old 01-13-2011 | 09:55 PM
fabrik8r's Avatar
fabrik8r
You could try the 10W Amsoil fluid change in the stock shocks. It may not be the finest possible suspension upgrade, but it is a very noticeable improvement for the cost of a quart of fluid and a few hours of your time. Worked well for me til I could afford some premium shocks.
82ndJumper
2014-2023 Touring Models
31
09-11-2016 07:33 PM
orinmorris
12-17-2014 06:00 AM
billbuzz
09-03-2014 07:33 AM
bagger76
03-18-2010 11:51 PM
roadkingdentontx
10-20-2005 01:05 PM
Quick Reply: suspension issues
