TC88 cam tensionner failure... wondering of...
Old 01-12-2011 | 03:05 PM
pit1600's Avatar
pit1600
Originally Posted by stafford
Pit1600 do you have to buy your parts in France? Why can't you order on line from someone like Zanottis or some of these other places discount prices. Not trying to be a smart a$$ just asking. What you're talking about there is highway robbery. Good luck
i bought most of parts by ebay in USA. Even with customs sometimes, the deal is a lot better. But for that and some other stuff i want to do it at my dealer (it's not an official) for 3 reasons : first, it's a friend; second, i trust him; third is that i want him to stay open.
In France, lots of little shop like him have stop their business. They could not beat internet and prices (french taxes, import taxes and so on). If all close, we will have the only solution to go to MoCo dealer with their more expensive labor prices and their look on our ape and 21"...
i want the best bank for the buck and i think that changing pads and bearings is not a bad solution for an '04 (an very old bike for afficial dealers). And i could keep my money for new fenders and a new paint for exemple.
I hope you understand my thoughts even if i'm not fluent
Old 01-12-2011 | 03:17 PM
pit1600's Avatar
pit1600
Originally Posted by FastHoss
Just change the tensioners and go about your bussiness,it will be fine.The timing chain is already smoothed down,the new pads are better material,it's all good.
Is it the solution you went with? you have change old tensioners for new ones? No problem since? Did you have change your cams?
sorry for all that questions but if you have went where i'm thinking going to, i'm a lot interested.
Old 01-12-2011 | 03:25 PM
MNPGRider's Avatar
MNPGRider
Pit, you are plenty fluent, we understand you well. We don't know about import tax, etc, but your quote on your original post is just plain high. Changing cams is not that big of a job that requires such a high labor cost, if adjustable pushrods are used, so you don't have to pull the heads.
Also, your bike should be worth more at the time of sale if you have taken care of the cam tensioner problem once and for all.
Old 01-12-2011 | 03:51 PM
djl's Avatar
djl
Originally Posted by pit1600
I have 2 solutions, one for S&S gear drive and one for HD update kit. He wants me to change the oil pump too to prevent problems.
For the gear drive, it will cost about 2700$ + labor
For HD upgrade kit, it will cost about 1500$ + labor
I was wondering why not only changing the pads, stay OEM and maybe just for fun change the cam (wondering of SE204 or Andrews26, Headquarter is not possible here). I will change pad every 12500 miles to prevent problems...
any help or opinion?
At first glance, the prices you were quoted appear over the top but not knowing what is included, can't say for sure.
You have the right idea. Save the $$$/francs/euros and replace the stock tensioners, change inner and outer cam bearings and either of the cams you mentioned will boost performance a bit but they both like more compression than stock and would perform better if you could get your hands on a set of '06 or later heads, deck them a bit for more compression and install them with a .030" Cometic MLS head gasket. You will get a seat of the pants kick from cams alone but more compression is necessary to optimize the bump.
You won't have to change tensioner every 12,500 miles. The old chain is "polished" from the previous miles and shoudl not wear down the new tensioners as fast. The problem with the old tensioners was the high, constant spring pressure applied. Just check the tensioners for wear every 12,500 miles; they should last a long time.
Old 01-12-2011 | 04:57 PM
Arnold63's Avatar
Arnold63
Save your money. Have your friend replace the tensioners,inner and outer bearings and call it good. I had mine changed at 33000 miles and also went with SE211 cams. Alot cheaper than the upgrades,and if I get another 33000 out of these,I'll change them again! I'm not worried.
Old 01-12-2011 | 05:07 PM
steelerdude1's Avatar
steelerdude1
DELETED posted new thread
Old 01-12-2011 | 05:16 PM
steelerdude1
I priced the pads out and they will cost around $120 + gaskets, Is this a job I can do myself? Will I need special tools?
Old 01-13-2011 | 02:47 AM
White Knight 04's Avatar
White Knight 04
Talking
If you have any mechanical knowledge you can do the work easily.. Yes you will need a blind bearing puller rent it from auto zone and a bearing driver... Pretty straight forward job!! But if you are that far in to it might as well go for the Andrews 26g cams I did mine myself at 24,000 mi and never looked back or worried since then... After the cam change it pulled like a truck and I had a real sense of satisfaction.... Also you don't have to pull the heads to change the cams... Just use adjustable push rods and use a set of bolt cutters to cut the old ones out... I also went with the S/S gear drive loved it.. Harbor freight also has blind bearing pullers and bearing drivers for about 40$ for both if you want to own your own I renter mine from auto zone and the sold me a high end one for i think it was 274$ but the one for 29$ and some change will work just as good...P.s. I'm not stupid just didn't see the one at harbor freight till I was done with the job... I have since traded my 04 off on a new 103 but my 04 88 ran very well.... Hope this helps you get a feel for the job !!! Jerry
Old 01-13-2011 | 03:30 AM
grbrown's Avatar
grbrown
Gentlemen, Pit is in France, so comparing prices is not helpful. Here in Europe we pay much higher prices than in the USA and even if we buy cheaper from the States shipping and import taxes, at our end, can bump up prices a lot!
Pit, while changing the stock tensioners is a viable solution, the best solution IMHO is to fit the SE hydraulic kit, plus a set of new cams. The gearset is even more expensive and I can see no benefit, whether or not crank runout is a problem. I have an S&S motor in my evo so am a fan, but have yet to tackle my TC88 and have no plans for gears for that.
Old 01-15-2011 | 02:33 PM
SecondChance!!'s Avatar
SecondChance!!
That dealer is hitting you dry!!!!!!! Have someone in the US buy it for you and ship it to you or you do it yourself. I just did my 04 EGC, TC88 with the SE upgrade kit, oil pump, SE 204 cams, Timken bearings, gasket kit, SE oil breathers, Stage 1 carb kit out the door, work myself, for just at $1100. Everything!!!! Done the work in just about 8 hrs. take your time, get the shop manual, and rent/borrow the bearing puller/installer and away you go. We made our own puller and it worked great.
Quick Reply: TC88 cam tensionner failure... wondering of...
