Bleeding front brakes FLHR
Old 02-11-2011 | 03:40 PM
iclick's Avatar
iclick
Originally Posted by PistonPuller
I bought a bleeder kit from HF for $4.99 worked like a charm.
Same here. Not much to it, mostly hoses and a small reservoir, but it works well and is easy.
Old 02-11-2011 | 04:27 PM
REVHAPPY's Avatar
REVHAPPY
Maybe you shouldnt be doing this............if you have to ask this question.
Old 02-11-2011 | 04:40 PM
not2kool's Avatar
not2kool
So you shouldn't do anything that requires asking a question? That would eliminate about 3/4 of the things I try.
Old 02-11-2011 | 04:56 PM
hubble's Avatar
hubble
Originally Posted by roadking2000
Yes I do and they are worth every penny. It makes bleeding the brakes easy and a one person job. You don't have to become a contortionist to do it when you have speed bleeders.
Once you use speed bleeders you'll wonder why you didn't buy them years ago. They are great. I have them on all calipers................
Old 02-11-2011 | 05:56 PM
bmcgc's Avatar
bmcgc
I bled my FLHT brakes a couple weeks ago.
I never got fluid to come out of the top of the bleeder. As soon as I cracked the bleeder I had fluid coming out from around the threads. I barely turned the bleeder so I know I didnt have it open to far.
I had the cover off the master cylinder and tapped both brake hoses about a dozen times each, squeezed the lever and got a bunch of air out. Repeated that a few times and no more air. Brakes work fine.
Old 02-11-2011 | 07:03 PM
ddm502001's Avatar
ddm502001
Sounds like the port in the bleeder screw is plugged in this instance a not out of the ordinary occurrence. I use a hand pump vacuum bleeder, pulls the fluid through the system and not had issues with low lever or pedal for brake engagement.
No H2O
03-11-2019 10:20 PM
jekyllandglide
04-15-2015 10:25 AM
Freedomrider13
Wheels/Tires
02-23-2014 09:28 PM
bmcgc
01-21-2011 08:43 PM
hedotwo
05-11-2008 06:19 PM
Quick Reply: Bleeding front brakes FLHR
