Exhaust Removal - need special tools
Old 01-11-2011, 08:57 AM
Robeuro03's Avatar
Robeuro03
Robeuro03 is offline
Default Exhaust Removal - need special tools
My new exhaust is coming next week. do i need a special tool for the O2 sensors? I built the bike from ground up so skills is not an issue. I just don't want to damage the sensors.
thanks
Old 01-11-2011, 09:14 AM
RollaMo's Avatar
RollaMo
RollaMo is offline
They do make a special O2 sensor socket, but you shouldn't really need it.
I've removed them without using that socket before.
Just have to be careful and not damage the connector.
Old 01-11-2011, 09:21 AM
Tazzrider's Avatar
Tazzrider
Tazzrider is offline
No special tool needed. As RollaMo suggested, careful with the wiring/connector. Once i break them loose, I hold the wires and rotate with each wrench turn so as to not bind the sensitive leads up.
Old 01-11-2011, 09:25 AM
twistr's Avatar
twistr
twistr is offline
No special tool needed (even though they sell one - marketing)...as RollaMo said just have to be careful and (not) damage the connector and (sensor)..I also strongly recommend using "anti-seize" when you install them on your new pipes.
Old 01-11-2011, 11:30 AM
FDHOG's Avatar
FDHOG
FDHOG is offline
Use a box end or open end wrench to remove the sensors. This way you wont come near the connector.
Old 01-11-2011, 11:51 AM
Grillfish's Avatar
Grillfish
Grillfish is offline
What I did, cut the zip ties and I unplugged the connectors, then removed my header. Once I have the header on the ground, alot easier to remove the 02 sensors and you can either use an open or closed end wrench (i think it was 7/8" on my 09). I then installed the 02 sensors on the new header with it still off the bike and did use some anti-seize on the threads.
My 09 manual says 30-44 ft lbs on the sensors.
Old 01-11-2011, 11:56 AM
bagman1's Avatar
bagman1
bagman1 is offline
Yup 7/8 it is!
Old 01-11-2011, 12:21 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
...or cut a slot into your socket for the wires. they sell them cheap, but I usually pick up single craftsman or snap on sockets cheap at the pawn shop and alter to my needs.
Old 01-11-2011, 12:24 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,249 Likes on 1,640 Posts
Or...put a tuner on that bad boy & don't worry about O2 sensors - tie-wrap them away & plug the bungs.
Old 01-11-2011, 02:34 PM
jrobinson424's Avatar
jrobinson424
jrobinson424 is offline
I agree with Grillfish. It is so much easier to just disconnect the wires from under the seat. They are quick disconnects. It is so much better and safer to take them out while the headers are laying on the table or floor. That way, you don't stand a chance of stripping the wires. Then you'd be screwed in an unpleasant way. Those things aren't cheap.
Quick Reply: Exhaust Removal - need special tools
