Motorcycle wheel Chock
Wheeldock is good what I had before went with this ... No Straps No Worries just lock down and forget it..
http://www.bikersgostrapless.com/
You Place and Tighten Down the Stationary Bar underneath your Frame .. the Front wheel rolls easily through the Mount on the deck between the Latches on Right and Left hand sides ..When the Bar mates up with Latches it locks down .. Probably didn't explain it well but best I can do ...
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
This is the one I use.
http://www.pingelonline.com/wheel_chock_removable.htm
You can pick these up on Ebay for $50 bucks, on average.
I use the Harbor freight chocks. Actually have both styles. They both work fine.
The more expensive style
http://www.harborfreight.com/motorcy...ock-97841.html
Has a larger mounting base so it is better if you have a plywood or thin metal deck.
I use the Harbor frieght model myself, but I think the Codor is probably the best one out there.
http://store.condor-lift.com/
