Converted to belt primary drive yesterday
Old 10-01-2006 | 07:19 PM
CNC WHEEL GUY's Avatar
CNC WHEEL GUY
Default RE: Converted to belt primary drive yesterday
Is this a belt drive that is concealed within the factory primary cover or is this an open belt drive setup?
Old 10-01-2006 | 09:23 PM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
It's not an open belt. The factory outer primary goes back on. I had to use a die grinder to remove a little metal from the inside of the cover to make clearance for the pulleys and belt. Once there was no mechanical interference, I put the chrome outer primary back on and the bike retains the stock look.
Old 10-01-2006 | 09:24 PM
Eyespy's Avatar
Eyespy
Bryan TTM, it's not wet, that would defeat much of the purpose of the modification. Is your final drive belt a wet system? No. BTW, since it's a belt drive, there is no need for the compensating sprocket (I assume that is what you are referring to when you say compensating nut). The belt has a damping property that eliminates the need for the compensating sprocket needed with a chain primary drive. Just like a chain final drive needs a cush drive hub in the rear wheel, and a belt final drive doesn't.
Old 10-01-2006 | 09:27 PM
Eyespy's Avatar
Eyespy
ORIGINAL: Grover
Now let's take it for a ride. Still waiting for the call.
I was off for eight days - go back on Tue -Wed, off Thur-Fri, but have to work Sat -Sun. Stop by the station next week end if you are in the area.
Grrr...it seems you always have days off that I have to work and vice versa. Last Sunday, while you were at the station, I rode out across Death Valley into Nevada, had a steak lunch .
Old 10-01-2006 | 09:52 PM
Bryan TTM's Avatar
Bryan TTM
ORIGINAL: Eyespy
thanks for the info...not interested in a dry belt drive
Old 10-01-2006 | 09:55 PM
Eyespy's Avatar
Eyespy
ORIGINAL: Bryan TTM
ORIGINAL: Eyespy
No prob, Bryan. Different strokes
Old 10-01-2006 | 10:01 PM
liltrk's Avatar
liltrk
I thought belt drives needed to be open to be cooled. I have seen cutaway primary covers on some.
Old 10-01-2006 | 10:31 PM
lp's Avatar
lp
Is there a wet belt drive?
lp
ORIGINAL: Bryan TTM
Old 10-01-2006 | 11:06 PM
springer_'s Avatar
springer_
First, I wish you the best of luck with your new belt install.
I run a 3" open BDL belt drive. Before that I had a 3" open Primo belt drive. I have had them on my bike for about 14 years and I beat them hard. I have not had a belt failure.
I have seen many belt failures on the narrower belts and enclosed belts. Belt technology has come a long way but I still don't trust enclosed belts.
Here is a picture of one that we used in a bike build we did last year. We only used it because the guy we built the bike for already had it. At the time he picked it up we told him that would be the weak spot. Well here is a picture of the belt after 700 miles.
Old 10-02-2006 | 02:11 PM
Eyespy's Avatar
Eyespy
ORIGINAL: springer_
NOw that's not a pretty sight! What belt drive kit was that that failed in 700 miles? I have the BDL 1.5" Kevlar kit, it has a one year warranty. I average 700 miles a week on the bike.
jberg
01-09-2019 03:30 AM
sly_buck
09-26-2011 08:01 PM
waynemags
Custom Models
06-14-2010 05:57 PM
dope_man_21
Custom Models
03-08-2008 11:22 AM
daryl71bus
Shovelhead
07-08-2006 05:47 PM
Quick Reply: Converted to belt primary drive yesterday
