As long as the sending unit is inside your fairing, the temp gage will indicate, if it's accurate, what temp it is inside your fairing. At what temp inside your fairing do the bridge decks start to freeze?
I ride in Alaska, as early and as late as I can. Granted the temp in the fairing does not take into account the wind, humidity or other factors but it sure gives me an idea when to start looking for ice. Accurate or not - it's better than nothing.
I would think at about 37* or colder. That is when most cars give you an ice warning.
If you are worried about the ice on overpasses and bridges, you should always ride in a large group of bikers, always at the back of the pack and watch for your friends to go down. I replaced my air temp with an oil temp and added a jagg oil cooler. I do agree that it is a grounding problem in answer to your original question.
My air temp gauge works well and is accurate. I thought about exchanging it for an oil temp gauge but the oil temp is what it is and I can't control it so who cares?
I have a 2011. The air temp gauge seems pretty useless. Doesn't seem accurate. And how do you figure out the scale. I think the dashes are about 7 1/2 degrees - come on.
Has anybody relocated the sending unit outside the fairing? If you have, where did you install it? Do the readings on the gage, after the sending unit has been relocated, appear more accurate.
