DEALER CHARGES to Lower a Ultra ?
Most recommend the Progressive 940 and the new CVO shocks? Both are gas charged shocks and the 940 are a 12" SHOCK WITH 13" RANGE WHICH sounds pretty good? The CVO has an adjustment and you turn it to compensate for the added weight and they never bottom out? I also have heard that the new air shocks that are from HD( Low Profile shocks ) have a different valving and the ride is excellent ?
For $50.00 and about 20 minutes of your time you can lower the rear of your bike 1 - 3". You still use your original shocks. You may decide you don't need to lower your front once you lower the rear.
Check out this site for a lowering kit/
http://www.road6customs.com/online-s...roduct=1136465
Be aware that if you lower your bike by using factory lowering shocks (12") like come on the Streetglide you will have a MAJOR decrease in ride quality. That 1" decrease in shock travel means the difference between a Cadillac ride and hardtail-like ride. Couldn't take the ride on my Streetglide (I'm old) and changed over to Ultra shocks and the difference was unbelievable. I understand there are aftermarket brands of the short shocks that will give you a much better ride than the H-D ones, but they are pricey. Do a search on this forum-there's a lot of info on this subject.
I've done it and do it all the time. I've ridden baggers that way for better then 10 yrs and I can promise you the ride quality isn't affected anywhere as drastic as that.
When done right it will actually improve the ride. We lowered a road glide with 11" progressive 440's in the back and shortened the front springs (w/ progressives). It lowered and evened out the center of gravity. The bike handled and road awesome. Why better then stock.
We've done a lot of electra glides (be it standard, street, ultra, classic or whatever) with lower shocks and in the end they have all handled as well as or better then stock.
Don't use blocks or brackets. That will change geometry in a negative way IMO.
The 12" HD air shocks when inflated correctly will be fine. Not as good as the Progressives but fine.
Dealer put lowering brackets on the rear of mine as part of the sale. The brackets are cheap and easy to install. Actually changing the rear shocks is an easy job. Figure parts and 1 hr labor.
The front is more involved, and more expensive. If your thinking about chrome forks, do them at the same time to save on labor charges.
Does anyone have a EG or UC with the Progressive 940 at 12" and a 12 " Front ? . I know that it can not be that bad of a ride if these bikes are lowered to 12" ? Most people have a BAD install or drop it down too much and thats why it is BAD But if you do a 1" drop with Good equipment it should be fine?
