Mounting Dunlop tire: "Arrow" aligned with valve?
Correct, the triangle is pointing to the wear indicator location. The yellow dot or the red dot if there is one gets aligned with the valve stem. Just make sure that valve is on the right side of the motorcycle and that the directional arrows point the way of the rotation of the tire. In some instances the yellow or red dot may be on the other side of the wheel when installed.
