Left side muffler shakes a lot
Old 01-07-2011 | 10:56 PM
customsoftail200's Avatar
customsoftail200
Default Left side muffler shakes a lot
I've been told by guys behind me that the left muffler shakes quite a bit while riding. I can see it at idle and when I rev it, the left bag seems o move more than it should to. I've checked the muffler clamp, and clamp by the trans also the bag support hardware and all is tight.. What else holds it in the back? Has anyone had this problem before?
Old 01-07-2011 | 11:33 PM
2000FiveOh's Avatar
2000FiveOh
It's not uncommon for the left side to shake a little more than the right. I've never seen one show it noticeably above idle though. All you can really do is start at the front of the pipe and work your way to the rear and make sure everything is snug, including the support under the rear fender. if all is tight just ride it. Sometimes these bikes have a mind of their own.
Old 01-07-2011 | 11:38 PM
hockey8787's Avatar
hockey8787
is the rubber isolator under the saddlebag support worn out or split??
Old 01-08-2011 | 01:03 AM
BackRoader's Avatar
BackRoader
My EG has done that since day one. Just a Harley thing!
Old 01-08-2011 | 01:16 AM
orbiker's Avatar
orbiker
You might check the saddle bag bracket.
If you get a header, you wouldn't have a problem with the left pipe. (just a thought)
Old 01-08-2011 | 08:15 AM
1flhtk4me's Avatar
1flhtk4me
My '06 Road Glide started to have an annoying squeek.The problem was the left muffler rubber bushing.
To stop the squeek,I crimped the metal bushing bracket to make it a tighter fit.This also reduced the shaking a little.
Old 01-08-2011 | 08:26 AM
EasternSP's Avatar
EasternSP
Veteran: Marine Corp
One day I noticed my left muffler was dragging on the ground. I had some zip ties available so I was able to tie it up to get home. I took the bag off and this is what I found. I had it mig welded but it broke again. I had it mig welded again with a backing plate and it has held since.
I've heard of other people having this same problem.
Old 01-08-2011 | 08:36 AM
IzZy63's Avatar
IzZy63
I've got the same issue on mine, changed the rubber grummet and still the same shake.
Old 01-08-2011 | 08:47 AM
harry.b's Avatar
harry.b
If you still have the stock pipes, check the bracket that comes off the front starter bolt. I noticed mine was broken in half when I changed the pipes.
Old 01-08-2011 | 09:56 AM
Bodean46's Avatar
Bodean46
I'd also look at the front motor mount. It may be the rubber broke.
