stock ecm must be ok on new bikes.
found this posted by Jamie of fuelmoto on another site. It looks like the stock ecm does a pretty good job at least on open loop. I am kind of suprised that it is not leaner. 2011 touring 96" stock ecm comparing stock pipes with cat to fuelmoto headers.
Thanks for posting this info MtClassic, but I'm not surprised that your not getting much response from it. Lot of folks just think the stock ECM is garbage and needs to be replaced with an aftermarket tuner. I had already researched this and knew it was very capable in the open loop. That's why I went with the inexpensive xied's to enrichen the closed loop. just saying!
The ECM calibration (Lambda table more specifically) is actually calling for an AFR of 12.84:1 in open loop at full throttle. The open loop areas are not generally the problem, the closed loop is where can see AFR's as lean as 15:1 as well as the surrounding blend areas
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
jamie, thanks for looking at this post. Where would you like to see closed loop in low load cruise say from 1500-3500 rpm 14.2-14.4? sound close? I guess I am just suprised that the stock ecm did so well WOT. On the PCV I know you disconnect the O2 sensors, what happens when you do this on the stock ecm? thank you.
