ROTORS: tips and what the hec is a "FLOATING" brake rotor???
The best maintenance you can do for your brakes is to disassemble them now and remove/ clean the pistons. When the pistons get built up with road crud they will not move freely. This is the major cause of warped rotors. If you see your brake pads wearing uneven, this is a sure sign of dirty pistons binding in their holes. Purchase a rebuild kit from the dealer, usually just an o-ring kit for the calipers and clean the pistons, then reassemble. Just follow the instruction that come in the kit.
How To Install Brake Pads & Caliper Maintenance
<li style="font-family: Verdana;">Brembo 2008 ~ Current Brake Maintenance Guide PDF Download<li style="font-family: Verdana;">Twin Cam 2000 ~ 2007 Brake Maintenance Guide PDF DownloadTwin Cam Brake Caliper & Control Illustrations Guide PDF Download
Floating rotors can also be damn annoying. They generally make a bit of noise as they shake, rattle and roll on the buttons that connect the outer ring to the carrier. The real question is, are you hard enough on the brakes to really justify the benefits of a floating rotor.
The picture below shows a true floating design but Lyndall Racing has a few interesting designs that I wonder how they perform and sound.
Paul from Lyndall can no longer sell the MMC rotors, his are only Stainless Steel made in China <QUOTE>: The APEX Performance Rotor is an ultra-light friction ring fully CNC machined from functionally gradient metal composite material and is fitted to a 7075 T6 billet Aluminum carrier with 16 mm Aluminum buttons. The entire 11.5” & 13” fully floating rotor weighs 1.8 pounds. <QUOTE> They do not sound like anything. They have a coefficient of friction of 0.6 whereas Iron has 0.6 and Stainless Steel has 0.5. Of course brake pads make a difference also. These are my 13" rotors with Brembo monoblock (made with one piece of aluminum for stiffness) calipers.
A floating rotor can move a 0.100" side to side but can not move forward and backwards. They self center in the brake pads and are most useful when the rotor gets hot.
If you don't have a floating rotor, DO NOT unbolt the rotor from the wheel, it will be warped if you do.
Wholly buckwheat. This forum rocks.
I'm getting a serious (and free) education after starting this thread.
Keep it coming please - good stuff!!!!!!!!!!
Still 50/50 on what type of rotors to get for my stock OEM '05 ultra.
Thanks.
Dave H. Appleton, WI
(Go Packers - Philly cheese steaks for us tomorrow
Thanks.
I give HD a pass on this one. Although there's no side to side movement, they are a two piece rotor/carrier unit connected by button fasteners. If you really cook the brakes, the rotor can heat up and expand without warping the carrier. This works for street riding. I am pleased with the HD floaters I had installed when bike was new. They are smooth, no pulsating at the lever and look great!
Guess I must be an easy going rider, never had any troubles with the brakes over heating. Like what I hear about floating disks, but seems like more small parts to cause problems. What is the gain of having more pistons per caliper in stopping power? Have heard the same pressure is applied regardless of how many pistons the caliper has. Not looking to hi-jack this thread, just thought it might apply.
wethead103
2014-2023 Touring Models
12-26-2015 09:09 AM
Hogpro
05-15-2014 04:53 PM
OneBlackFly
10-26-2008 09:39 AM
