HK RADIO Scratching CD's
Old 01-06-2011, 03:06 PM
shore's Avatar
shore
shore is offline
What's a CD?
Old 01-06-2011, 03:26 PM
BlackPearl#1's Avatar
BlackPearl#1
BlackPearl#1 is offline
+1!! I agree.
Originally Posted by jeff.georgalas
I've got over 8 hours of music on one single c.d., so I don't have to change them often, and my head unit will still tell me what it's playing and my handlebar controls work, so I'll skip the ipod.
Old 01-06-2011, 05:52 PM
Iron Cross Audio's Avatar
Iron Cross Audio
Iron Cross Audio is offline
Former Sponsor
CD's left in their jewel case and carried in the tour pack or bags will end up with small circular scratches. They are vibrating and rotating in the jewel case. The CD drive makes no physical contact with the recorded area of the disc, so leaving it in the drive should not result in scratching.
Old 01-06-2011, 07:54 PM
V2Evo96's Avatar
V2Evo96
V2Evo96 is offline
OK-- for reference and what it's worth....may or may not be applicable to your individual problems but:
Service Bulletin M1289 issued 11 October 2010 nominates a change to the handlebar clamp screws of touring models built after approx 07 October 2011.
Bikes affected are all touring models including CVO bikes equipped with the HK radio system From MY 2006 to 07 October 2010.
The essence of the bulletin states that if a problem with CD skip or other CD problems exists, the two forward handlebar clamp screws may be contacting the bottom of the HK radio chassis causing skip/other issues via vibration.
You (or your dealer if your still in warranty) need to look for contact between the forward handlebar fasteners and the bottom of the radio chassis. New fasteners are available that will eliminate the problem if it exists on your bike.
Only models presently in warranty will be covered to have the screws replaced by a dealer of course!
New fastener part no. is 12600003 and you will need 2 of them.
Replacement time nominated is 0.8 hours.
Old 01-06-2011, 08:37 PM
BlackPearl#1
Default Thank you
This is why this is the greatest forum!! I really appreciate your input.
Kris
Old 01-07-2011, 09:47 PM
Potato_Potato's Avatar
Potato_Potato
Potato_Potato is offline
Are you sure they are not getting scratched stored in your saddlebag? I ruined a few that way when I first got my SG.
Old 01-24-2011, 06:00 AM
BlackPearl#1
Default not the saddlebag
Yep, I am sure I know the difference, because I have ruined them that way too. But you can tell for sure these marks are from it spinning, not from vibration or getting hit or moved or whatever ya want to call it. The prime example, as stated by someone else, I make a new one and put it in the bikes player and nowhere else, when taken out you can see the damage begining to happen after a few weeks.
steelerdude1
2014-2023 Touring Models
12-04-2015 12:45 PM
Taranwanderer
15
05-29-2015 06:27 PM
rcpilot_971
Audio Systems
07-21-2013 01:51 AM
GMRO
07-17-2013 09:21 AM
aviscomi
01-03-2010 08:45 AM
Quick Reply: HK RADIO Scratching CD's
