Help needed with Harley audio amp
http://www.harley-davidson.com/en_US...ts/-J03651.pdf
Good luck with your installation. Hopefully, you also received the lengthy wiring harness required for the installation.
Carl
It's a straight forward installation; my best friend installed one on his '06 EGC two years ago and is very happy with that set-up and Hogtunes speakers front/rear.
Just go to the "genuine motor accessories" and select "touring" then select "electronics" and you'll find "audio." Alternatively, you can type the p/n in the search function.
Carl
Carl
TexasD
Audio Systems
06-17-2017 10:55 AM
7619206a, amp, amplifier, amps, audio, davidson, harle, harley, harman, harmankardon, installation, instructions, kardon, pn, ydavidson
