My Project.....
OIL COOLER: (check part number for your make/year/model bike)
My Bike....Harley-Davidson® 09-10 Touring Oil Cooler Kit, 26155-09 On ebay for around $250.00
HOSE:
Aeroquip Performance racing hose
Part #FBA0600
Keep in mind this hose is high pressure type, however, I've used this type of hose in my business and race car builds for both HP fittings and push lock fittings for years and it works fine. Just don't use the push lock fittings on pressure over 500 PSI. The hose barb on the cooler is push lock, the hose will install using some motor oil and a little effort, the other end of the hose I used HP fittings because I had them in my garage collecting dust. If you want push lock here is the part... http://cgi.ebay.com/ebaymotors/Aeroq...mZ260713858424
HP fittings:
2 of these.... http://cgi.ebay.com/ebaymotors/Aeroq...mZ290513469023
Oil filter adaptor fittings:
2 of these... http://compare.ebay.com/like/2302751...=263602_304662
2 of these or four if you use push lock fittings at the adaptor.... http://compare.ebay.com/like/2302751...=263602_309572
One note about the hose. You could use push lock instead of HP hose but I have never found it with the diamond casing which is high grade tight weave and looks great!
Hope I covered everything. After I hit 50 the mind tends to wonder. lol
First, I love this mod, looks GREAT ! Just a slight side, I saw a guy with a sweet rigid that had covered the shift rod with slip over "steel braided" hose cover (like used for fuel line) and used the worm gear "clamp" style fittings at each end. . . . that looked really sweet to me and would go nice with this too I think. . . . . just a thought.
Keep us up to date on your mods, looking GREAT so far!
