Tire Pressure Question
i wouldn't worry about whether it's before sunup when you air your tires, or that they're totally cold, that's pretty insignificant. just make sure that you check your air pressure and if it's low add what it takes to bring it up to specs. with that question being addressed, i'm almost sure you know how to maintain the tire pressure in your car.
I check mine first thing in the morning. I keep them at 36 front and 40 rear. Just changed rear with 13600 miles on it and front had a little over 31000. If I have to ride to get air (as it seems my compressor is very popular with my buddies) i check it first then ride to station and add what was low to it then check it again the next morning, hopefuly my compressor has returned by then.
Well, if you have stock dunlops, you are probably looking at 40 in the rear (with a passenger), and 36 in the front. You didn't ask for pressures in your opening post...you asked what to do about pressure after riding to the station.
Any biker worth the title would know what their tire pressures should be. You only have to look in the manual once.....like the day you bought the bike. IMO
There is no such thing as a warm tire pressure reading.....too many variables.
I got my '06 Fatboy last October - had it in the local Harley shop to adjust the clutch slack in Dec - I had not checked my tire pressure since I bought it. Never rode a Harley before, and memories of the old Triumph I had back in '72 evidently did not make it to 2010, because I didn't think they were low. They cautioned me about tire pressure, and aired them up.
It felt like I was riding w/o rubber. When I got home, next morning, I checked w/my gauge, and they were 35 psi. That's lower than recommended (40), but they feel so damn hard. It doesn't seem right, somehow.
Yes, I realize that the owner's manual will tell me, as will the tire itself. However, I don't have it with me, but I do have a computer and some free time. Looking to ride as soon as I get home and I thought asking the guys on this site would eliminate the need to dig it out and waste riding time
Every vehicle has it's own rated pressure for tires.
Most cars have it listed in there door jamb.
40 rear, 36 front is pretty average for our bikes.
The only exception that I know of, are Metzler tires. For some reason they like a lot of pressure.
I don't run them on my spoke rims because of that. Besides, they wear fast.
for now, a suitable solution for you that wouldn't cost a lot would be a good quality bicycle pump. our tires don't require much volume, and a few pumps would bring your pressure up to where you need it to be. i suggest one with the metal screw on coupler for the valve stem rather than a plastic clip on type though.
Keep a quality gauge in my car and on the bike. Check bike cold, in garage. Use quality bicycle floor pump. Haven't ridden the Cannondale Mtn bike in years, but the pump gets used. If you use air at gas stations, Chevron policy is free air. Even though the air compressor states 50 cents, go inside and ask for 'tokens' for the air compressor. Found this out when I asked for change for the air, and they gave me the tokens and said Chevron policy, no charge.
