I used the Snap On torque adapter on my White Lightning. Went to dealer to calculate how to set torque wrench values, were no help. Had a Proto tool catalog with a chart to properly use the torque adapter. At least ten years and no leaks.
Does anyone know how much more torque to add on the torque wrench setting when using the Toruqe Wrench Adapter. Because I know when using an extension or deep well socket you loose some of the torque off the wrench.
Hey guys,nevermind recalculating the torque wrench. I found this website where all you have to do is put in the length of the extension,length of the torque wrench,and the desired torque value,and it will tell you where to set your wrench. http://www.belknaptools.com/extcalc.asp
