PC5 vs. SERT
The SERT is one of the best systems out there; the TTS Mastertune is probably the only one better. I am a believer in going with the tuner's preferred system. I would feel better about the tuner if he just said, "hey, I am a SERT guy but if you want me to tune with the PC5, I can but the tune probably won't be as tight". If the guy likes the SERT, go with the SERT; if he likes the SERT, he should be fine with the TTS Mastertune as well. The SERT can be upgraded to the TTS Mastertune but if you haven't bought a system yet and are considering the SERT, go with the TTS; more advanced features.
If you are the one that wants the PC5, go find a tuner that prefers working with the PC. These systems are just tools; match the tool and the tech.
Having had both on bikes that I currently own; IMHO I would not go with what the tuner likes necessarily. I had a SERT put on after the 103 BB kit was put on the SG and it ran like ****. Took to a "reputable" HD store that had a supposed wizkid tuner (twice) and had it dynoed.....still ran like ****. Several weeks later took the bike to another well-know MN HD dealer and had their wizkid dyno the bike and it ran a little better but still not great. End of the summer had a PC5 installed by a tuner from Dynojet and he did a dyno. It never ran as good and I could have saved myself a shitload of money. Point being: unless the tuner realllllly knows his ****; then a SERT is a waste of time and $$$.
DJ PC-V, SERT, SEPST, TTS... All are good products. Which is best- no real winner in my opinion because to me, it's only as good as the person doing the tune, and his/her working knowledge of the tuning device used. Sure each system has pro's and cons, but I am not sure there is a clear winner because I don't know of anyone who has bought ALL the various tuning systems, installed them on the same bike one at a time, and then did tunes to determine which system gave them the "best" tune in the end. That may not be the best way to look at it, but to call one system better than the other is very subjective. Better how?- cost, number of parameters, range of adjustability per parameter, etc. A dyno tune done by a professional who knows the dyno fundamentals, the bike's true needs, and the tuning device's capabilities is all that matters in the end. A Dyno jet person is most likely best with a PC-V. A H-D tech is most likely best with a SERT or SEPST. A TTS guy is probably best with a TTS unit. Ask each person his/her opinion, and there will be various favorites... The only thing I can recommend is to do research on all the systems, know your end goal, and then try to make the best decision for yourself... Good luck
Lots of variables here. PC vs. SERT is sorta like Ford vs. Chevy. I have had the SERT on 2 bikes and have been very happy. Had a V&H Fuel Pak and it seemed to do okay. My tuner is a great guy to work with and we communicate well. If you aren't going to a guy that has a sniffer you are probably wasting your time. Guessing on AFRs doesn't cut it. Just my 2cents.
