dakota digital
RE: dakota digital
Don't have a picture of mine without taking things apart, but it is mounted under the fairing kind of above the headlight. Splice into a switched hot wire, ie, wire to cigarette lighter, and put in a slip coupling. This will let you disconnect to remove the fairing. You don't have to use the cig. lighter wire, just any wire that is only hot when the ignition is on will work. If you have a test light, you can probably find such a wire that is not even in use. I think that is how mine is done. Had it done at the dealer before I picked the bike up, so I'm not sure.
Hope this helps.
Regards,
Bill
Hope this helps.
Regards,
Bill
