Using the cigarette lighter as a power point?
Old 12-28-2010 | 07:43 AM
wingman05's Avatar
wingman05
I would plug in a tire inflating device and would blow the fuze. I switched over to an Electrical Connection socket with an internal fuzed wire and it solved the problem.
  #32
Old 12-28-2010 | 07:53 AM
Steel Billet's Avatar
Steel Billet
Originally Posted by 05 Ultra
I replaced mine with a powerlet outlet. Looks better and I can use their 90 deg plug so it clears the tank.
I know what power outlet your referring too but the "90 deg plug" who's is it and what are you running with it? Sorry if I missed something. I'm not a very smart person and I always need more details than most people.
  #33
Old 12-28-2010 | 08:54 AM
electra glide's Avatar
electra glide
May be a coincidence, but I noticed my lighter out after I plugged a tom tom into it. Tokm Tom may or may not have been the culprit, I don't know. Haven't tried to fix it yet, and it's been a year.
  #34
Old 12-28-2010 | 09:06 AM
Stash905's Avatar
Stash905
Originally Posted by 1st 96 ultra
this has been on here before and I think it was kind of figured it was the room of some of the longer plugs on a full turn so they just say don't use it
Buy a Road Glide and then there is no problem like this. :-)
  #35
Old 12-28-2010 | 09:12 AM
TxFLHX's Avatar
TxFLHX
6th Gear
My 2010 SG manual states the same. I need to check the fuse size because I planned on running my Slime brand tire inflator that I used to use for my atv's.
Heck, I didn't know that I had a cig lighter until I read the manual!
  #36
Old 01-01-2011 | 04:34 PM
1st 96 ultra's Avatar
1st 96 ultra
I wired a power outlet in my tour pak for charging my ph and that kind of stuff
  #37
Old 01-01-2011 | 04:43 PM
rushbass's Avatar
rushbass
No problems powering my GPS or charging my smart phone...
maybe the key is making sure the power adapter for whatever device you are using is not too long, so it doesn't make contact with the tank when the handlebars are turned fully to the left...
  #38
Old 01-01-2011 | 06:39 PM
Rat1's Avatar
Rat1
I tried using mine to charge my cell phone. Popped the fuse the also runs the guages. Put a larger fuse in and you should be fine.
  #39
Old 01-01-2011 | 07:16 PM
whitetruk's Avatar
whitetruk
Originally Posted by 2011FLHTK
I use it for the GPS, for the Ipod and for the phone. No problems yet.
ditto
  #40
Old 01-01-2011 | 07:38 PM
bill1nat's Avatar
bill1nat
Originally Posted by rotti
On page 72 of the owners manual for my 08 Street Glide it states: "The lighter is not intended to be used as a power port for electrical devices. Damage to the lighter receptacle may occur."
Thats strange - anyone ever have any issues?
Use it all the time NO ISSUES
Quick Reply: Using the cigarette lighter as a power point?
