Using the cigarette lighter as a power point?
Old 12-26-2010 | 05:30 PM
sgdiesel's Avatar
sgdiesel
No problem providing you don't exceed fuse capacity.
As stated above BEWARE of the tank on full lock
Old 12-26-2010 | 05:44 PM
1st 96 ultra's Avatar
1st 96 ultra
this has been on here before and I think it was kind of figured it was the room of some of the longer plugs on a full turn so they just say don't use it
Old 12-26-2010 | 05:51 PM
mastery's Avatar
mastery
Originally Posted by Udawg
You don't have a problem with the GPS plug hitting the tank? I have an 11 FLHTK too and wanted to plug my Garmin in there but it has such a long plug I thought it might hit the tank.
You can get an aftermarket plug with a angle to the plug in so that you miss the tank on a full handlebar turn. Can't remember where I got mine, but you should be able to find one if you search for it. I use the Garmin 765T with it plugged in the cig lighter and it doesn't rub.
Old 12-26-2010 | 06:09 PM
Turbo Turtle's Avatar
Turbo Turtle
My personal observations over the years have influenced my use of lighter sockets.
Being as they're originally designed for lighter use, their is a slight chance of grounding a charger or power supply cord if bumped beyond what might be considered normal.
A power specific supply socket does not have the extended grounding clips which catch a lighter upon depressing, thus greatly reducing the chance of grounding out or shorting out my/your expensive equipment.
Nuf said? ask me how I know!
not just my $0.02
aka Bob
Old 12-26-2010 | 06:22 PM
2011FLHTK's Avatar
2011FLHTK
I haven't had that problem. Nothing has hit the tank. As mentioned earlier you can use a shorter plug if it is a problem.
You can also use a regular mobile USB charger with most garmin GPS units. You don't always need the Garmin charger.
Old 12-27-2010 | 08:38 AM
SUPRPIG's Avatar
SUPRPIG
I fold the cord and wrap it with a shoe string around the bar with some slack. You can always use the string for something else on the raod camping etc... in fact need to replace that with some parachute cord which is way stronger.
Old 12-27-2010 | 08:43 AM
sooie's Avatar
sooie
6 year EX smoker
10 FLHTK and i have my GPS in it
Old 12-27-2010 | 09:14 AM
Shrug's Avatar
Shrug
Originally Posted by Faast Ed
Heard of a few that came wired with opposite polarity.
This is quite common and it warrants checking the polarity before plugging in a device. The cigarette lighter is just a short and is irrespective of polarity.
In terms of current draw, the lighter will support just about anything you throw at it. Its supporting circuit is designed to handle a direct short (the cigarette lighter) which is dramatically more current than a GPS, phone, MP3 player, etc.
Old 12-27-2010 | 11:21 AM
Udawg's Avatar
Udawg
Thanks Mastery. Found one on eBay for $5 and it should be a great temporary fix so I can use my old Garmin on it.
Old 12-27-2010 | 11:26 AM
dgretz's Avatar
dgretz
Have run my Escort radar detector and Sirius radio units from receptacle for years before finally hard wiring them.
Quick Reply: Using the cigarette lighter as a power point?
