Quick question about heims on shift linkages
Just installed a shift linkage with heim ends. Got everything tightened down, but noticed that the heim itself has a little rotational movement when playing with the shifter, and looks like it's moving around a little too easily.
Guess I'm a little weirded out by it not staying in one place. So, the question is: Is it supposed to move that easily? Everything is tight (bolts holding it on, nut adjusting the length).
Am I screwing something up, or is this natural? Thanks for the support...the older we get, the more we worry I guess
All heims are not the same.Some may be looser than others.
Thanks 1FLHTK and boog. Figured that was the way it was, I just hate seeing loose things anywhere on the bike. I'll keep the original in the saddlebag in case somebody needs it out on the road.
Other than flipping the front bolt around so it comes outward instead of inward (the long "wire nut in appearance" nut was way too long to clear the cylinders), and the "looseness" of the heim joints, this was an easy 10 minute swap out.
there's a big range of quality when it comes to heim joints, also known as spherical rod end bearings. i found that out when putting together the throttle linkage and other controls on one of my old hot rods. speedway motors in lincoln nebraska has a great selection, and the cheapest ones are loose, where the better quality ones have much tighter tolerances meaning almost zero slop. it makes a difference. look in streetrodder magazine for ideas as to where to find great quality rod end bearings.
I went with the round, polished linkage from Landmark (http://www.landmarkmfg.com/Linkage_Round.html) and I'm impressed with it, just didn't know if this type of joint should have some movement to it when moved by the hand. I expected some play while being operated by the foot though since there's more force being applied.
Legalcarry
02-15-2009 09:39 PM
