LED Bulb Help
Old 12-23-2010, 07:51 PM
Old Bones's Avatar
Old Bones
Old Bones is offline
Default LED Bulb Help
I bought these LED bulbs for tail light and brake lights. Because of the way they are shaped I can not push them in the socket far enough to turn and lock them. Is there another brand that works in Harley directionals.
Old 12-23-2010, 08:03 PM
rerb95's Avatar
rerb95
rerb95 is offline
there are several different styles and brands, there are several members on here that have a ton of knowledge on LEDS, look up the Shrink on this forum, he has a lot of LED knowledge! I think one brand name is custom dynamics.... I'm sure there are a lot of others!
Old 12-23-2010, 09:01 PM
tidbit1's Avatar
tidbit1
tidbit1 is offline
Smile
Look up badlandsmotorcycleproducts.com lots of LED help.
Ride safe
Old 12-23-2010, 09:22 PM
JohnnyC's Avatar
JohnnyC
JohnnyC is offline
I actually ran into a similar situation when I swapped out my brake-light bulbs. In my case I was real close to making it work. My issue was that when I put the lens on and tightened it down, it would short the hot center conductor in the socket to the metal ground of the bullet designed cases. I was able to use a pair of needle nose pliers and pull the entire socket forward to where they work. I also put a small patch of electrical tape on the tip to prevent shorting.
Old 12-23-2010, 11:01 PM
Old Bones's Avatar
Old Bones
Thanks, I went to custom dynamics along with other sites and this note keeps popping up.
"- Note: Not for use for Replacement on HD Turn Signal Housings"
Old 12-24-2010, 09:56 PM
captainjack's Avatar
captainjack
captainjack is offline
may also be because they are 1157 and not 1156, 1157 have offset pins and will not fit 1156 sockets the rear lights are usually 1156 with the pins opposite one another just my
Old 12-24-2010, 10:17 PM
Mr Cujo's Avatar
Mr Cujo
Mr Cujo is offline
Beat me to it...
Generally --
1157 - Dual element bulb for brake/turn signal applications
1156 - Single element bulb for turn signal applications
This bulb should work in the brake light socket of your bike (Brake/run) - but not likely in the turn signal housing.
Old 12-25-2010, 08:09 PM
Old Bones's Avatar
Old Bones
2011 RG uses 1157 with the two contacts for running lights and brake lights, single contact (1156) is for running lights only. The plastic on the LED bulb comes in contact with the inside of the housing before it is all the way in the socket. I guess no one has installed LED bulbs in HD directionals.
Old 12-25-2010, 09:12 PM
pargenz's Avatar
pargenz
pargenz is offline
Lots of folks are running LEDs. Perhaps the particular ones you've got won't fit your sockets, but that's not the case with all LEDs.
Check out Custom Dynamics or Walters Workshop - compare theirs to yours and you may see the difference.
Old 01-14-2011, 05:35 PM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
It's a Harley, of course those LED bulbs wont work. Just run standard Harley bulbs. I dont have a problem with my Harley bulbs, I like my Harley bulbs just the way Harley made 'em.
Quick Reply: LED Bulb Help
