1999 RK to carbureted
Here's a list of pn#'s to get him started. A google found this. I've updated the part numbers to current. Much info out there on the net on this conversion
Engine mount (with slot for choke) ……. 16315-99
Choke cable ……. 29229-88D
Choke elbow ……. 27580-88
Choke boot ……. 27582-88
Intake manifold ……. 27613-99
Manifold seals ……. 26995-86B
Seal ring (carb/manifold)…… 27002-89
Ignition Harness ……. 32435-00
Manifold sensor (MAP) ……. 32416-10
Manifold sensor seal ……. 11291
Retaining clip ……. 38723-99
Retaining clip screw ……. 68042-99
1. Stock Petcock- 61338-94D
Stock CV40 Carb- 27412-99D
You will also need the ignition module of your choice
