Relocated the Air Shock Valve
Old 12-30-2010, 08:16 AM
09StreetGlider's Avatar
09StreetGlider
09StreetGlider is offline
I found an online retailer in 4mm x 2.5mm, the size the OP used.
http://www.kineticllc.com/catalog.as...showprevnext=1
I'm going to order from them and see if it works. I have a few riding buddies that will split the cost with me, as we have all discussed this mod, but couldn't locate the right tubing. Thanks OP for the size info.
$13.06 for a 25 meter length + shipping = $21.48
I already have 3 friends in on the order with me, so that's less than $5.50 for a very convenient mod.
  #32
Old 12-30-2010, 08:30 AM
Marine Trader's Avatar
Marine Trader
Marine Trader is offline
Good idea, thanks for sharing.
  #33
Old 12-30-2010, 04:35 PM
2black1s's Avatar
2black1s
2black1s is offline
Originally Posted by sgdiesel
Careful here, I do not believe it is 5/32" but rather 6mm metric. It is crucial that you get the right tube as the fittings are push loc type fittings that rely on the pipe diameter being 100% correct to seal and work
4 mm is the correct size, not 6 mm. 5/32 is ok also. In fact, the tubing I bought has both 5/32 and 4 mm markings on it. There is only about .0013 difference in the nominal OD size between 5 /32 and 4 mm. 5/32 = .1562 and 4 mm = .1575.
  #34
Old 12-30-2010, 05:36 PM
sgdiesel's Avatar
sgdiesel
sgdiesel is offline
Tks, fair enough. Could have sworn it was 6mm last time I checked when this topic came up but clearly got it wrong. I agree that for poly tube that difference is not an issue,
Not sure what the threads are in the shocks but if metric fittings originally (Parker I believe) then one needs to proceed with caution if replacing those as well. It doesnt take a lot to cross thread brass fittings
  #35
Old 12-30-2010, 06:30 PM
Twinrider's Avatar
Twinrider
Twinrider is offline
Originally Posted by sifularson
This is what I have . . .
RELOCATION KIT
Thanks for that info, just bought it and am looking forward to checking the shock pressure on a more regular basis. And thanks to the OP for starting this thread. I always thought the position of the air valve was a pita.
  #36
Old 01-07-2011, 10:28 PM
Twinrider's Avatar
Twinrider
The relocation kit was a piece of cake to install and works great. Excellent value at just $22.49.
  #37
Old 01-07-2011, 10:33 PM
2black1s's Avatar
2black1s
2black1s is offline
Is that simply an extension that attaches to the stock valve? That's what it looks like in the ad.
  #38
Old 01-07-2011, 11:13 PM
sifularson's Avatar
sifularson
sifularson is offline
The kit comes with a bracket and a longer valve as well as some tubing in case the stock tubing is not long enough. My kit arrived but I haven't had the time to install it. Maybe this weekend.
  #39
Old 02-02-2011, 06:02 PM
mcain49's Avatar
mcain49
mcain49 is offline
I use the HD pump and have had no issues with it so far. I wish I'd known there were cheaper ones around though. I thought it was a bit overpriced for $50. I like that it doesn't leak off when unscrewing from the valve and it seems to be of reasonable quality. Haven't considered moving the valve because its fairly easy to reach by lowering the left saddle bag lid on my 10 UC.
Mike
12-02-2017 04:30 PM
Sparky88
05-05-2010 07:51 AM
Roosterboots
The General Motorcycle Forum
15
12-21-2009 11:05 AM
Quick Reply: Relocated the Air Shock Valve
