New to Harley , need opinions
Old 12-21-2010, 08:14 PM
bbstacker70's Avatar
bbstacker70
bbstacker70 is offline
Default New to Harley , need opinions
Looking to do a stage 1 this winter. Have decided on the SE air cleaner , SERT and Vance & Hines Dresser duals. To save lots of money and to keep it quiet I was considering keeping the stock mufflers. Has anyone done this ?. My main reason for the stage 1 is heat reduction. Will the bike with this set up breath well enough to cool down. If I need to go with new mufflers I like the Monster Rounds. Are they quiet enough on the highway for touring ?
Thanks for the input guys
Old 12-21-2010, 08:20 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
getiing a good tune, regardless of pipes or air intake, made the single biggest difference for me. midframe heat deflectors helped me not feel it so much either.aftermarket headpipes will move the heat to where u wont feel it but doesnt(in my opinion)reduce it.
Old 12-21-2010, 08:35 PM
PistonPuller's Avatar
PistonPuller
PistonPuller is offline
True duals will in fact reduce heat because you will be eliminating the collector. You wont have as much heat build up and exhaust will flow more freely
Old 12-21-2010, 08:39 PM
handsomeboy1's Avatar
handsomeboy1
handsomeboy1 is offline
If you wish to save money get a PCV for half of the cost of the race tuner
Old 12-21-2010, 08:57 PM
RK14SGS's Avatar
RK14SGS
RK14SGS is offline
The bike will be cooler, the tune will be better, the performance will be better, and with the Monster Rounds the sound will be awesome!!! ENJOY!!
Old 12-21-2010, 09:00 PM
07FLHT's Avatar
07FLHT
07FLHT is offline
+1 And get the auto tune modules, you won't be sorry! Fuel Moto doubles the warranty Plus lifetime support!!
www.fuelmotousa.com
Old 12-21-2010, 11:46 PM
mfuchs2004's Avatar
mfuchs2004
mfuchs2004 is offline
Oddly enough, the higher flow a/c will make it run hotter. Will give you more power though.
It's the fuel turner that'll fix the lean condition, but only if you set it up right. The SERT is okay in the hands of a quality tuner, but the pcv from fuel moto is much more useful out of the box and saves you money.
Don't fall for the pipe hype. Pipes have to be matched to the way you'll drive your bike. Contact Jamie at fuel moto and tell him how you like to ride. He'll give you a shopping list and very good prices to boot.
Old 12-22-2010, 06:59 PM
sgnden's Avatar
sgnden
sgnden is offline
+1 and yeah...get e GOOD tune on 'er. The rough estimate maps are often not exactly right-on IMHO.
Old 12-22-2010, 07:25 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
I have a different take on it. I like to save money on each bike I own- that translates into MORE BIKES in the garage! right now I have 5. 4 Harleys and a Honda Trail 90
If your header pipes have a catalytic converter- you may want to consider removing it or getting a different header pipe- the cat can be a bottle neck to flow. ( cats in 2010 and 2011 models, some 09 models ( california)
other bottlenecks are the stock restrictive mufflers and the air cleaner with it's back cover.
I use supertrapp supermeg slip on mufflers. they use a diffuser disc system to control sound and flow, more discs= HP and noise fewer discs = torque and quieter. I use 12 disc right and 8 discs left on my 96" with stock 09 headers
This design offers superior performance, control over sound AND it you change your motor, you retune the pipes to match.
I have used their pipes for over 20 years on a number of bikes.
the ness big sucker with a chrome backing plate is a nice tidy install, the chrome plate is easy to wipe off when washing the bike, and looks good if you have the black/chrome motor.
the filter media is washable and oilable ( like a K&N).
ebay $115 shipped from easterpc
some guys just go at the plastic backing plate with a hole saw on the bottom
tuning:
with the increased flow, the EFI needs to be tuned. I am put off of the piggyback tuning systems by all the posts from Guys who are trying to get it working right.
I am using nightrider.com XIEDS which will run you about $125 shipped. these plug in line with your O2 sensors and under most riding circumstances will tell your ECU that it needs to richen the mixture slightly- this helps with the high heat and matches the increased air.
IF I were to do cams or headwork, I would certainly plunk down the bucks for a more complex tuning system and dyno sessions. I'll probably leave the motor the way it is for the life of the bike.
so I am at $240 with XIEDS and Ness big sucker, and I kept the supermegs that were on my evo bagger for 15 years- so no cost.
BTW the Screaming Eagle Nightstick is made by Supertrapp and I've seen 2 of then on the classifieds here recently for $100 each ( plus ship)
I could easily have gone with a stage one system from a shop or dealer and been close to $1000
Mike
Old 12-22-2010, 07:43 PM
txfxstrider's Avatar
txfxstrider
txfxstrider is offline
Quick Reply: New to Harley , need opinions
