Fairing removal necessary to change headlight bulb?
Sometimes I just shake my head and say, "WTF?"
One screw takes off the trim ring, three screws take the headlight out. Squeeze the harness and remove from bulb. Pay attention to how the spring clip holds in the bulb, release bulb, replace, reattach clip, plug in harness, put in three screws, attach headlight rim.
And removing a fairing is easier?
Thanks for the many responses
Seems it can be done both ways then. The one advantage of removing the fairing seems to be that the headlight will remain properly adjusted. Of course yet another advantage would be that while the fairing is off you can inspect for broken brackets, fraying wires, loose nuts and bolts.
Thanks again to all.
