string type vs mushroom tire repair
After purchasing my '10 Ultra Classic and going with the "laced (spoked) wheels", I found out that there is an inner tube in both tires...
What can I do on the side of the road with a flat now...? Glad I purchased the flat tire roadside service/warranty. Do I have any other choices?
http://www.ride-on.com/
Also +6 on the Stop-n-Go plug kit. I also have their small pump and I carry CO2 cartridges.
www.patchboy.com
I use their mushroom plugs and self vulcanizing plugs. Both work great.
Carry these all the time cause both my cars have run flats. The mushrooms work great.
I use punctureseal (www.punctureseal.com), same principle as 'ride-on' , its been tested up to 150mph so no worries about keeping speed down, unlike some other products. I also have a SnG kit I carry 'just in case' !
I also carry the stop-n-go plug kit w/ slime electric compressor. Don't need to have glue (which is usually dried up when you go to use it) w/ the plugs. Also, the amount of CO2 bottles required to inflate a 180/65-16 tire is like 8-10, if it's done perfectly. I plugged my tire and rode it out another 7000 miles until the tread was gone, and was always careful to keep it under 100 mph w/ that repaired tire :-)
[quote=ronbeejer;7677473]After purchasing my '10 Ultra Classic and going with the "laced (spoked) wheels", I found out that there is an inner tube in both tires...
What can I do on the side of the road with a flat now...? Glad I purchased the flat tire roadside service/warranty. Do I have any other choices?[/quot
With my RK Classic I had Slime for tubes and the compresure..now with the Ultra I have plugs...
