Gassy Mess
When it gets toward the top,it takes for ever to top-off the tank.It takes a few minutes to squeeze in the last 1/2 gallon or so.
>>I just run the pump until it shuts off automatically<<
I never do that. I don't trust it enough to shut off and not drench a hot motor and pipes in gasoline. Or fall out as I've seen that happen, and although I'm sure you keep a hand on it, I've seen people who don't. I pull the rubber seal back with my hand, so the pump will flow, and watch it fill to where I want it. If you keep a rag in the hand you're holding the rubber seal back with it will smoother most splashes.
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
Yeah, that.
- It's easy and you don't have to buy any gadgets.
Use a couple of the paper towels they keep at the pumps and toss 'em when yer done. Simple enough.
i don't like the design of the harley touring tanks other than the road kings. they have the gas cap on the right=correct side of the tank rather than in the center. it would have been much more convenient to have installed the filler cap on the right side so that when it's on the center stand the cap would be at the highest point of the tank. some of the problem is that the tank tunnel where it goes over the backbone of the frame is close to the filler neck, and that makes every bit of gas splash around in the tank while fueling.
