Deluxe Tour-pak Hinges
Old 01-04-2011, 10:08 AM
BigGdawg's Avatar
BigGdawg
BigGdawg is offline
Originally Posted by bdp
More likely to crack when it gets cold and the ABS material contracts slower than the screw. I see you are in Canada and maybe it won't get any colder, but are you parked in a nice warm garage right now.
Case in point. Buddy of mine altered a windshield on his softtail here in South Texas on a 90 degree day. (Drilled glass just big enough to force screws in). A few weeks later we went to Colorado and upon reaching the top of Wolf Creek Pass (temp about 40f) watched the windshield crack at two of the screw holes.
That is a good reason why not to "fix" something unless it is broke. Now it needs fixing again.
  #72
Old 01-04-2011, 11:30 AM
badjustbad's Avatar
badjustbad
badjustbad is offline
Agree, my instructions read the same as yours, but when the screws wouldn't go in, I ran the 3/16 bit through the holes and all is well
Like you, I think the right way to install the parts is to drill the holes to ensure the correct size. There seems to be a degree of tolerances with the holes (I suspect because they are created during the molding process, and not drilled afterwards.) - I didn't need to drill the screw holes in mine, others say you have to.
The point I was originally trying to make is, we spend a ton of money on H-D parts and yet Taiwanese instructions come with the parts. Then when something goes wrong with the part, it isn't covered under warranty. It's a good gig for H-D.
  #73
Old 01-04-2011, 11:56 AM
Raaze07's Avatar
Raaze07
Raaze07 is offline
Originally Posted by sifularson
Installing the hinges was not nearly as nerve wracking as drilling the lid to install the luggage rack.
Having done both - I have to agree with you! Much larger pucker factor on the luggage rack...
  #74
Old 01-04-2011, 02:34 PM
speckfisher's Avatar
speckfisher
speckfisher is offline
Good Thread. I quess I'll have to install some myself.
  #75
Old 01-05-2011, 07:49 AM
djkolp's Avatar
djkolp
djkolp is offline
I read this post yesterday, and just had to run out to the dealer and buy a set of hinges. While I was there, I looked at a 2011 CVO with the price tag at $41,600. Yup, the Milwaukee metal shop hinges attached. So wrong.
Once the rivets were removed, drilling out the holes with a 3/16" bit worked perfectly. Someone here wanted to know the torque value of the screws. 20-25 in lb (2.5-2.8 nm)
  #76
Old 01-06-2011, 04:14 AM
1st 96 ultra's Avatar
1st 96 ultra
1st 96 ultra is offline
yup and did you notice the $35000 Ultra Tri Glide , yea the tin can hinges also , but just think it gives us some more to get before we take our new bike home
  #77
Old 01-07-2011, 01:40 PM
Dynarider04's Avatar
Dynarider04
Dynarider04 is offline
Well worth the $50 IMO. I did have to drill slightly bigger holes for the hinge guide pins so they would seat flush w/ the tour pak lid. All in all....a worthy mod!!
  #78
Old 01-07-2011, 01:58 PM
EasternSP's Avatar
EasternSP
EasternSP is offline
Veteran: Marine Corp
Received 24,869 Likes on 9,332 Posts
I don't suppose H-D makes them with the skull theme.
  #79
Old 01-08-2011, 08:40 PM
djw479's Avatar
djw479
djw479 is offline
First mods I did when purchasing my used 2008 RG. When installing the tour-pak those cheap-azz, tin hinges just stood out all the time.
Checked out the Kuryakyn hinges, but their ugly.
  #80
Old 01-09-2011, 09:54 AM
ultraherbie's Avatar
ultraherbie
ultraherbie is offline
Default Tour pax hinges
I did my hinges in Nov. I drilled out the rivets but if I were to do it again I would grind the heads off with a Dremel tool instead of using a drill. Have a look.
Quick Reply: Deluxe Tour-pak Hinges
