Deluxe Tour-pak Hinges
#52
Now if the instructions suggest that the procedure for drilling out the rivets is to continue to drill right through the tour-pak, I have a probelm with this. The metal of the rivets is much harder than the tour-pak plastic so the drill bit would deflect off and damage the tour-pak. Not cool!
The screws do fit without using a drill bit to enlarge the holes (mine are in and I didn't drill them), but the fit is very tight. The screws worked like self taping screws.
#53
The instructions do not say to drill out the holes (At least my instructions don't.). The instructions (steps 4 and 5) say to use the 3/16" bit to drill out the "eight hinge rivets". It says nothing about drilling out the tour-pak lid or base holes.
Mark
#54
Maybe we should form a committee to determine the absolute best way to install these.
2 weeks later...
Committee findings: 1) Call ahead to set appointment. 2) Take new bike in trailer back to H-D. 3) Explain to Service Tech that in spite of 14 different methods explained on line, you are not confident enough to drill out a rivet and you would really prefer a trained professional install your new hinges. Don't forget to thank your Svc Tech and be sure to tell him you tip, then wink.
2 weeks later...
#55
Same here. No way that machine thread screw is going to screw through the TP material and into the hinge and not create some stress points.
#56
2 weeks later...
2 weeks later...
#58
#59
