Deluxe Tour-pak Hinges
1. Follow the directions and remove the stock hinge pins and lid before you start removing rivets.
2. Drilling the rivets works however I found that grinding the heads off with a Dremel is much easier then drilling around the lid seal. You're working on the opposite side away from the seal.
3. Use blue tape to cover the paint in any area you are working. One slip with the drill or dremel and you'll wish you did.
4. You will need to drill the holes out for the new screws since the screws are slightly bigger than the rivets.
5. You will only need extra hands when it comes time to bolt the lid back on. I managed without help.
I just did two in the past couple of weeks......the 1st was a "learning" experience. Follow the above and use a new drill bit........(not the self starting kind).
btw, the instructions don't say a word about drilling the rivet holes to a larger size to accomodate the new screws, but you will need to. Just make sure you drill only the amount needed to fit the screws in
This is a must upgrade. The stock hinges look like crap.
Drilling or dremel, both work to get rid of the rivets. Always use a new, sharp drill bit. You need not put much pressure on the rivet when drilling because a good bit will cut through the curls of the rivet quickly. Once the rivets are out and the old hardware is removed, don't drill the holes any bigger than necessary for the new little fasteners. You can do this job yourself if you must, but it's not recommended. There is way too many opportunities to **** something up and create some bad scratching. My wife helped me once I was ready to put the new hinges on. She also helped me hold-back the rubber gasket when it was time to drill out those rivets that hide under that gasket...so as not to nick or damage the gasket.
Yes, 4 hands are recommended on this job, not mandatory, but recommended.
And yes, it is a sorry damn shame that a CVO model comes with the **** stock hinges. But CVOs come with a lot of stock **** that shouldn't be on a bike of that price class.
$5 hinges on the Tourpak.
Even the salesmen are shaking their heads on that one!!!
Mine went ok. Still not finished completely, the hinge part is for the most part. I am also installing a TourPak Bra, so I haven't put the lid back on yet. Waiting for the Velcro to sit 24 hours, then will put it all back together.
I went and got 2 new drill bits. I had a 3/16", but it had seen better days. So I got a new one and a spare. Worked fine, and drill bit still looks like new. Tried the hinges real quick for fit/looks. No problems.
Sure does look lots better! Good $50 spent!
