Dyno results
Dyno results
just got a call from my indy. had 211 cams, s/e adj. pushrods, and a d and d 2-1 installed on my 09 roadie along with a s/e tuner. already had heavy breather on the bike. results were 91.6 hp and 99.6 tq. haven't ridden but will get it back tomorrow. he said it did haul butt. numbers seem ok to me but imput appreciated.
That's one of my favorite cams. If you've installed it at stock compression, it will be a little sluggish until the motor spools up a little. It's a fair trade off for a really strong mid range, though. If you install it at 10.2 to 10.5 compression, it's a great all around cam. One of the best sounding idle from a bolt in cam. Peak numbers can be misleading, and comparing one dyno chart to another one done on a different bike at a different tuner is basically an exercise in barstool racing. Wait until you've ridden it before you try to form an opinion.
Little more info on your build?
Did you look at the new TW555 woods cam that just recently came out? These are kick a$$ cams. They would have gave you 5hp and about 10lbs of torque more. See Fuelmotto dyno sheet for a 96in with TW555 cams installed. It's your bike and the 211 cams should do alright for you. Good riding.
