Winter storage question
I wouldnt think it would hurt the frame during storage, after all, its steel. Just make sure its secured to the jack well (strap it down) and make sure the jack is locked (dont want to trust 900lbs over a period of time to hydrualics only, if your jack is bad it will drift down) and it takes weight off your wheels (no flat spots) Put it on plywood or something to get it off the concrete, stabil in the tank, hook the tender up and cover with cloth sheets, you should be good to go for a few months. Good luck and stay safe.
I have both bikes up on stands for the winter. Saves a bit of space in the garage too.
Well I have done it in the past but just jacked it enough to get weight off tires without getting bike in the air. I could do that with the old jack I had and still use the safety lock. With the harbor freight jack I have now, to get safety locks to catch, I have to get it completely off the floor. Was just wondering about the pressure being put on the frame.
Thanks
Thanks
