Lope of a Woods 555 cam
my ol shovel with a andrews a grind and su carb. sounded alot like this..when they come out with a cam that can make a twinkie sound that good I'm buying stock in it!!!
http://www.youtube.com/watch?v=5n0Z4...eature=related
Not sure how the lower idle can hurt the comp. Oil pressure in these bikes is not something to worry about. Flow is the worry. These newer bikes have plenty of flow with the new pump. I have mine at 830 with the tmax and maybe will go a little lower once it relearns the curves a little.
Crap need a cold shower after that one.
low idle can and will effect battery charging. I have also seen where it contirbutes to ultra short life on the stator as it tries to work harder and if there is a week spot in the windings it will fry. Had a bro go through three stators until we figured out he was setting his idle way down about 800 or so, I'ts been 2 years on the same stator rpms set at 1000-1050.
