SHOW OFF your roadking
#997
Shows how I laid out Kenwood Radio, Amp, Speakers, also I added two 12 volt Plugs (white wire) to be able to charge cell phone, etc.
I used Heavy Wire to power components. The Red/Blk heavy wires going down thru rubber grommet is the quick disconnect
The Rockford Fosgate's small size works great and you only need Velcro to mount it on top of radio
I love the Reckless Fairing. Looks great ,Gel coat only
You can see the large Terminal block for the main power wire that distributes power to everything
#998
Could you share a little bit about how easily disconnectable it is? I love the fairing idea, but I would want to remove it easily when desired. This pic above seems to show it being quick detachable like the windshield is. How'd you run the wires?
#999
It is like the Battery Tender connector..just run a new wire from your battery,go under the gas tank, to the area around steering neck with these 2 wire type connectors...buy a long one so you have no splices.. the short piece (coming from the power connector inside fairing) goes thru rubber grommet makes connection just outside the fairing..It is the only connection...other than the windshield rubber pieces the fairing brackets slide into,,,,,but I'll tell you I loosen my Passing lights
and move them down onto a blanket on the front fender when I make a switch from one setup to another...
#1000
