LED Head Light Comparision JW & TL
#101
Don't really want to weight in on a personal choice like that...
I personally like the chrome look better, but my bike is Cobalt and Bright Silver...
Travis really likes the look of the black headlight on his dark (sorry forgot the name of the color) Street Glide...
That one's your call...
#102
Garemlin-
The Phase 6 addresses the lack of light directly in front and does an overall redistribution of the light pattern.
At this point - you need to have a discussion with whatever supplier you choose and make sure to verify you are going to receive the model that has 6 LEDs on for low beam.
-bogie
-bogie
That sounds easier said than done. I can see alot of I dunno's in my future. LOL
#103
best way to locate a distributer near you is to use the Contact US on JW's Website. They will get you in touch with a distributer in your area.
#104
Hello all. Kuryakyn is now carrying our LED Passing Lamps that have been discussed here. Just thought I'd pass along the link for everyone...
Kuryakyn's site: http://bit.ly/gnEzLE
Installed Photos of the lamps: http://bit.ly/hwO0ob
Let me know if there are any questions.
Thanks,
Jerry Lee
Thanks,
Jerry Lee
#105
#106
Read thru the thread again... just wanted to summarize...
The Kuryakyn and Custom Dynamics 7" LED headlights are made by Truck-Lite and are a plug-n-play fit.
Truck-Lite has updated their headlight, which addressed the concerns presented in the review Travis & I did. They call the new one the 'Phase 6' - with revised optics and now having 6 of the 10 LEDs energized on low beam (versus 5 before). The lens is still polycarbonate (versus glass for the JW/HD headlight. The JW/HD passing lamp lens is polycarbonate)
Truck-Lite is also making LED Passing Lamp replacements that are a plug-n-play fit for HD – available now thru Kuryakyn.
Travis & I are doing an updated review to compare the updated TL HL and their PL against the JW/HD HL & PL - watch for a new thread sometime next week (shooting for 2/23/11). We'll title it "UPDATE - LED Head Light Comparison JW/HD & TL" to make it easier to find.
The JW/HD HL & PL are now being offered either with a chrome or black interior.
JW/HD is offering a 5-3/4" LED headlight - but it won't fit the Road Glide. The JW/HD 7" won't fit bikes with nacelles and requires a new mounting bucket for use in batwing fairings.
While I agree an E-Code lens with the 70/65 Osram H4 bulb is better than stock (I had the Cibie lens with the 70/65 H4 bulb from Daniel Stern Lighting) - wait 'til you see the pictures in the updated review - we had the halogen out on the street with us this time... LED is BY FAR better…
While I haven’t compared HID – my biggest concern is most HID available for bikes is a conversion… gives the ballasts, wires and bulbs. But the bulbs are an ‘arc’ light source, and putting those into a lens/reflector designed for ‘filament’ source – I question the effectiveness (arc & filament bulbs each present the light on a different axis); not to mention not being DOT approved. Also, most HID are a single bulb – means either you don’t have high beam; or high beam is accomplished by moving the bulb to use a different part of the lens/reflector (even more questionable, unless on the much more expensive high end product); or high beam is accomplished with a paired halogen bulb (and the advantage??). While they may be better lighting than halogen, not being legal or specifically designed for bikes…... It appears even HD is no longer offering their HID headlight unit (which was designed for bikes and DOT approved) – which was priced at the same as the LED headlight, used halogen for high beam, with replacement ‘burners’ (bulbs) costing $195…
Watch for the new thread…
In case anyone is wondering - neither Travis nor I work for any of the companies or distributors mentioned. We are simply riders who enjoy sharing knowledge about new products - especially ones that make us safer.
Respectfully,
-bogie
Respectfully,
-bogie
Can't tell you how much we all appreciate the effort you and Travis put into this but I imagine you've gotten that already!
Are you planning to post that on a separate thread? If so, please post the link here so we all get the notice. I, for one, am "really" looking forward to reading it.
Thanks again for all your hard work and Ride Safe,
Steve R.
#108
#109
Alkisma,
The installation is pretty stright forward. When you install the new mounting ring, I beleive you will only use 4 screws, 1 on top, 1 on right side and 2 on left, when facing the bike. The aim is almost right on, but I would aim it yourself just to make sure. When you install your Trim ring back on, it will be tight and may have to use a little extra force to get it on. The LED HL will plug right into the stock connector.
Let us know what you think once you get it installed.
#110
Here is the link also http://********/wevqu
We are just about finished with the Updated Review and will be posted in the next day or two. We will add a link in this post to the new post with the updated review.
Thanks,
Travis
