cat removal from 10 headpipe audio file
#51
2. new muffler sounds better than stock
3. new muffler runs cooler than stock
4. 48-50 mpg
5. cause i wanted to?
#52
When you say does not slow down through put....I assume you are talking about back pressure? If so......why does the SE Street Performance touring mufflers state that they are designed specifically to work with the header catalyst equipped bikes? I'm guessing they are saying that meaning performance as opposed to sound?
I'm actually asking that as a question more than a statement trying to learn as a I go
#54
#55
#57
The newer headpipes run about 100 degrees hotter and I can attest to that. No real difference in noticeable performance and the sound is slightly more muffled.
