Flag Mounting Options
I plan on attending a wreath laying ceremony this Saturday at our Veteran's National Cemetery and I would like to attach a flag to my bike for the ride. I have a Street Glide, so I don't have a tour pack or a luggage rack. Does anyone have any suggestions on how to SAFELY and SECURELY attach a flag to a bike that is void of any good mounting points? I have checked with the dealer already and they don't have anything, and I don't have time to order something, so I probably need some Home Depot style solutions!
I've got the Rivco mount on the Ultra. Works great. Easy install. Easily removed when not needed (two pins removed and slide flag mount off) and leaves very little evidence of mounting hardware when you take it off. It is well made and good quality chrome. You can use it with one, two, or three flags.
Since becoming a PGR member I have also been wanting a flag mount. If I have the pillion on and passenger backrest with the luggage rack I could secure to that but the wife has yet to go on a PGR mission. As I not long ago started riding without pillion when solo with a Mustang fender bib I got to thinking somebody should come up with a flag pole that would screw into the rear fender where the pillion/bib secures. Bike just looks more sporty IMO with the bib. Not trying to hijack the OP's thread but if anyone has other ideas besides what has already been mentioned...
Get a piece of pvc with a bigger ID than your flag pole about 18 to 20" long.
Paint it gloss black to blend in, cap the bottom end and tye wrap to your back end.
My flhtcu had space between the side bag and fender and the saddlebag support was exposed so I cut a slit in the end of the pipe and let it straddle the support bracket, zip tied the top of the pipe to my tp docking point.
Also drilled through the pvc and flagpole and installed one pin to keep the flag from coming out.
You will have to massage it a bit to make it fit over the lip of the hard bag, but they do fit, and they do work. I used blue painter's tape to protect the bag and it worked like a dream.
I have also used chrome fishing pole holders from Wal-Mart and attached them to the side bag rails, but didn't like the look, so took 'em back off. On bikes with no tourpack, this option looks/works better.
