exhaust leak
Old 09-25-2006 | 04:11 PM
dawg's Avatar
dawg
Default exhaust leak
I found my muffler clamp loose and muffler loose the other day and it had some black soot around the pipe connection so I tightened it. Today I checked it and it was still tight, but there is more black soot. Obviously it is still leaking air at the joint. What can I put on to seal it?
Old 09-25-2006 | 04:15 PM
bountyhunter's Avatar
bountyhunter
Default RE: exhaust leak
Not another loose exhaust clamp, [sm=WTFsgign.gif]! How about some high temp duct tape[:@]?
Old 09-25-2006 | 04:19 PM
glide's Avatar
glide
Some high temp silicone will do the job. I would also open up the end of the pipe a bit to give a tighter seal. Also set the clamp up to the leading edge of the muffler over the slits for a better seal.
Old 09-25-2006 | 05:02 PM
dawg's Avatar
dawg
ORIGINAL: bountyhunter
I know, I know T-Rex CLAMPLESS I'll try the high temp silicone. What's the best way to open up the end of the pipe a bit?
Old 09-25-2006 | 05:05 PM
glide's Avatar
glide
A pipe expander would work well if you can get your hands on one. If not, then you could take the pipe and muffler to a muffler shop and have them expand it on their hydrallic pipe machine. Otherwise it would be a shoemaker job at best.
Old 09-25-2006 | 05:10 PM
Neckball's Avatar
Neckball
I just went through this over the weekend. I had my slip-ons off for some maintenece and I put them back on the way I saw suggested on this forum. Two new H-D Torca clamps ( replaced the Vance & Hines clamps) and put some of the Permatex Hi-Temp copper silicone where the muffler slips on the head pipe. I could see where there was an exhaust leak at the front of the slip-on on each side. Guess what? Now what little decel popping I had is gone. I knew an exhaust leak could cause the decel popping and I guess that was my problem. After taking a minute to compare the two side by side, there is no way the V&H supplied clamp can apply as much force as the H-D clamp. You're comparing a 1/4" bolt to a 3/8" bolt. When I was torquing the clamp, I felt like I was collapsing the pipe, it's that tight. But all is good now.
justincollins1
01-02-2013 02:31 PM
hdgzr
06-23-2011 09:37 AM
HD101st
Exhaust System Topics
07-06-2010 05:34 AM
ekcivic1
02-26-2009 01:45 PM
Mathews2
05-31-2007 06:39 AM
Quick Reply: exhaust leak
