Synthetic Oil
Yeah use AMSOIL 20/50 for the motor and primary, than use redline shock proof gear oil for the tranny. The 20/50 is too thin for the tranny to keep it quiet. I had the 20/50 from factory in 07 and as soon as I got the bike home I drained it and my trannys been quiet ever since, 25000 miles and runs quiet and smooth. Oh I ride a 07 FLHTC
---and I use the factory recommended products.
I have 4 Harleys in the garage right now,Twin Cams, Evos and Panheads.
I have owned many brands of motorcycle over the years.
My experience tells me to use products purpose made for these bikes- oil is a crucial part of the cooling system on these bikes.
and change at or before service intervals- ALWAYS store a bike with fresh clean oil.
my newest bike is a 2009, I can't believe how nice and clean the oil is coming out at changes, with I still do at 3000 miles.
oil is cheap, filters too
MK
MK
6 speed - Amsoil 75W-140 Extreme gear oil
5 speed - Amsoil 75W-110 Extreme gear oil
6 speeds have helical cut gears and exert much more side pressure on gears under heavy load conditions.
Nothing else is a substitute for the above recipe
HD oil is over priced s__t.
i was using royal purple max cycle for the first two years of ownership on my 08. then royal purple magically went from 7.99 a quart to 12 bucks a quart. that's when i went back to syn 3 harley oil. most of it is finding what you like and changing your oil and the right filter as per schedule.
