Street Glide Cigarret Lighter
Old 11-29-2010 | 11:44 AM
Flintshooter54's Avatar
Flintshooter54
That cig lighter heating up pulls a lot more power that that Garmin. I know it is for a shorter time frame but still the Garnmin is a trickle compared to the lighter. Although I have not used it to power a GPS I use it to charge a cell phone all the time on my 2010 Limited.
Old 11-30-2010 | 01:47 PM
casique's Avatar
casique
Sounds like I'll try it and see what happens. Thanks for the repplies.
Old 11-30-2010 | 01:55 PM
TitoFTW's Avatar
TitoFTW
I use the stock cigarette lighter port to charge my phone, to power my heated clothes, and I used to use it to power my xm before I got the unit under my fairing installed. No problems so far.
Old 11-30-2010 | 02:04 PM
ICIBUY's Avatar
ICIBUY
Originally Posted by Texas Fat Boy
I use mine for the GPS and it has never blown a fuse.
............and the plug has never fallen out either.
^^^ Yep, what he said! I have never had a single problem!
Old 11-30-2010 | 02:47 PM
jpalm's Avatar
jpalm
Default No problem
You should be okay...I use mine to power two 500 watt halogen lamps, a coffee maker, griddle, computer, television, satellite and DVD player, all at the same time...It does blow a fuse when I hook up the hair dryer though .
Actually, I leave my mp3 player plugged into it for hours on end when I'm riding and I'm yet to have any issues.
Old 11-30-2010 | 03:07 PM
DBlass's Avatar
DBlass
I made a harness to from the battery charger connector behind the side panel, up to my windshield bag. I used it to charge my iPhone and run a pump for an air mattress while camping. I had to up the fuse on the charger circuit to 15 amps though. When I don't need it, I disconnect it and put it away.
Old 11-30-2010 | 04:15 PM
nevets61's Avatar
nevets61
If it'll take the current draw of a cig lighter, it'll certainly take the 1-2 amps of a GPS... I've run mine their for days at a time, main reason is probably cause any power plug for GPS or other device will hit the tank if you turn full left ****... Just be cautious of this.
Old 11-30-2010 | 04:44 PM
TXCOMMISH's Avatar
TXCOMMISH
My wife uses is all the time to power her,,,,,,,,,uh,,,,,,,,,,,,nevermind.
Old 11-30-2010 | 05:30 PM
sat4314's Avatar
sat4314
you could plug in a portable TV and mount the screen to the handle bars if you like. It will not pop a fuse.
Old 12-01-2010 | 09:29 PM
FloridaFLHX's Avatar
FloridaFLHX
Same for me. Use it all the time.
Quick Reply: Street Glide Cigarret Lighter
